Are you talking about for the side tilt of the 3pt hitch?What tilt cylinder is everyone using? I'm not having much luck finding one.
Yes sir. I would love to order from you but the last I check you were backed up 22 weeks and I need (want) it now. Tired of climbing on and off to adjust itAre you talking about for the side tilt of the 3pt hitch?
I don't think that they have any that are specifically built for his model of tractor.Summit hydraulics has tilt cylinders: https://summit-hydraulics.com/product-category/hydraulic-cylinders/?filters=cylinder-type[5087]
They may not..I didn't look up the range for the sidelink on the 3560. You'd obviously know the details on that more than I!I don't think that they have any that are specifically built for his model of tractor.
The couple that I have seen are more of a generic type. Not saying they they don't have specific model units. It takes time to get all the ducks in a row so to speak.
One is close. Mine is 15 3/8" - 20". I don't know if 5/8" would make that much difference or not.I don't think that they have any that are specifically built for his model of tractor.
I was looking for off the shelf options but I'm going to call around on Monday. ThanksAny local hydraulic shops nearby ? Easy for them to make,given a few key numbers...
The best that you will get without a long wait is from WR Long. 5" stroke, top 3/4" ball clevis is 1 9/16" wide at a 6* angle. Lower clevis has three 5/8" pin locations with a 15/16" inside clevis width made with 3/8" material. Pretty well matches the factory link, actually better since Kubota uses the same adjustable link for all of the Grand Ls even though they should not be the same.One is close. Mine is 15 3/8" - 20". I don't know if 5/8" would make that much difference or not.
I will call my dealer on Monday too.It looks like landpride has one for the L series. See the link below. The spec's list all of the top and tilt options for a bunch of different models.
Land Pride
www.landpride.com
I ordered a top link for my LX.
@WRLongBenex is a member here now.Check with WR Long. They have started to sell T&T units to retail customers. Should be 4 weeks or less and about as close to what I provide as there is.
I don't think that anyone has the correct side link in stock yet.
And just for an FYI, I am now at 26 weeks minimum.
Check with WR Long. 252-823-4570
