River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
Got a few inches of snow late last week and the back blade and front blower made quick work of it. Been a light ....very light winter to date (of course now that I said that.....)
Finally had a little time with my friend who is an electrician so we put in a few outlets into the Morton Building since we had power run to it when our solar project went in the Fall. We also installed a large overhead light with a temporary extension cord until we get warmer weather to run permanent wiring. He was able to grab a couple of these large overhead LED warehouse lights from a job site where these were being replaced with something else......Like daylight in there now.
I also had to replace the rear ROPS light so I just went with a decent unit from TSC, nothing special and is disposable if/when it dies. IMG_5948.jpeg IMG_5947.jpeg IMG_5946.jpeg IMG_5927.jpeg IMG_5926.jpeg
Trapper Bob
L4701, Wicked grapple, 7’ box blade, 6’ Wicked bucket, SVL 65-2 w/4 in 1 bucket
Jan 17, 2022
446
820
Andover, KS
Drove the tractor around my brome field searching for prickly pear cactus. Found some & relocated it to an old chicken coop that I plan to burn soon. I filled the inside with wood & will add an accelerant. Do you think this will get the job done? IMG_9974.jpeg
Reactions: 6 users
mdhughes
L3901DT
Dec 10, 2014
1,484
1,594
Ste Geneveive county, MO
Fell another blonded Ash tree today. Here are couple pictures of the 60" logs I got out of it. These are the 4 butt logs. I went 60" instead of 80" because it was getting pretty muddy. We had rain and then snow Friday and it got up to 53F today and I wasn't sure about the extra weight. I was able to get 6 of the logs blocked up and split.
Reactions: 10 users
In Utopia
L175 FEL
Apr 21, 2013
671
202
Utopia,Tx/Pasadena,TX
Drove the tractor around my brome field searching for prickly pear cactus. Found some & relocated it to an old chicken coop that I plan to burn soon. I filled the inside with wood & will add an accelerant. Do you think this will get the job done? View attachment 122661
That looks like it should be spectacular, pics when you light it off.
3,587
Changing the fuel filter was always a pita, because the engine side cover was in the way, blocking the fuel bowl & filter from dropping down & out.
While working on the glow plugs, I pulled the side cover off and used a 2 5/16" chassis punch to cut some clearance, so that the fuel bowl & filter will drop out the bottom without disturbing the cover.
Reactions: 6 users
mdhughes
L3901DT
Dec 10, 2014
1,484
1,594
Looks factory. You would have thought they would have made it easier to get to then that.
3,165
From my experience with a similar amount of cactus to get rid of the answer is NO.
The cactus is loaded with moisture and won’t really burn well. It will start growing in size as the moisture vaporizes and then the ears will pop. The popping is strong enough to dislodge and throw coals a foot or two so be careful with that.
You might get it burnt partially with that amount of wood but you will need to add more to that (larger pieces) to keep the heat up for a longer time.
My process was in a 55 gallon “burn barrel“ and first attempt was to fill barrel about half full of wood and get it burning. Then I added the cactus but that was a slow process since too much cactus would start to extinguish the fire so you had to add the cactus at a judicious pace. So we then switched to fire in barrel and adding some cactus to fire and using an expanded metal “grill” on top of the barrel and placing cactus on the grill. Adding the cactus directly to the barrel still limited the fire and heat so we started with just the fire in barrel, cactus on grill until it popped and was charred then dropped that into the fire. That seemed to speed things up somewhat so we used that method until we were done with the cactus we collected.
I do think you will do some damage to the cactus but I think you will have some remnants that will still be able to grow. Now if you intend to load more wood or have more fires in this same spot you may be able to get it all burned.
I am still finding cactus plants and digging them out by the roots but believe I am winning the cactus eradication ”war” on my five acres since I have to work to find a cactus plant most of the time. I find a large cactus just out in places where I know that I walked by ever once in a while and just don’t know how it got that large without being seen.
11,757
View attachment 122712 View attachment 122713 View attachment 122714
Very nice job! That chassis punch is cool. (y)
Trapper Bob
Jan 17, 2022
446
820
Andover, KS
Thank you for the info, I never thought of “grilling before killing” them. (Sorry, couldn’t help myself) The cactus was not in the best of shape when I dug them up. We went thru a period of sub-zero temps which hurt (not killed) them. They were kind of purple on the side exposed & green next to the ground. It is amazing what the cactus can endure & still survive.
I also believe I am winning my war on prickly pear on my 242 acres. I’ll watch the fire & add wood as needed. I don’t want any to get away.
Do you use herbicides on the cactus? I’ve read Remedy & diesel fuel works pretty good.
3,587
Thanks!
I have a couple sets of them, plus a couple loose ones, including this somewhat unusual rectangular punch, cuts a hole .856 x 1.014.
5,188
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
275
510
Moseley, VA
Worked on regrading the slope down to one of the small ponds. Years of cattle heading down to get water made ruts and bumps 2' to 3' deep. A real pain to cut the trim with a brush cutter as you could not get much stable footing. Well I took several buckets out and used that to fill old stump holes that had settled in the field. Carefully backed down with the tiller and then took my old troy built tiller to the edge to loosen things up where I could backdrag with the bucket. I then raked it by hand and put some seed down then worked it over with an old 8' double cultipacker. Should be in good shape come spring/early summer. IMG_7050.jpg IMG_7052.jpg
Reactions: 13 users
