Pallet Forks for a BX
OrangeB7100
1990 B7100
Dec 19, 2022
Winfield, IL
I purchased the Amazon forks. They arrived yesterday via UPS. Driver was not thrilled they went UPS. Too heavy and in a cardboard box that was failing.
No visible damage to the equipment. Connected up to my B7100 and loaded up some large pieces of limestone.
Forks are definitely oversized for my little tractor. Need weights on front end. Standing on the unloaded forks I can get the front end bouncing but not off the ground.
Bottom bar already splitting along the seam. Will work for my simple purposes but would not recommend unless you planning on fixing with some welding up of any failures. Fortunately I have a brother with a welder.
BonnySlope
BX2380FEL, Add-A-Grapple, Box Blade, Rake, Rear Blade, HR12 Tiller, Flail Finish
Apr 11, 2021
146
126
NW Oregon
I also purchased the 3 PT hitch forks from Amazon but ended up building my carryall on it, it was cheaper then the carry all frames at the time.
I also have 36" forks for the front and your right after forklift frame and forks it limits loader power for us, me more then you. Carry_All_5.jpg CarryAll_4.jpg Ended up shortening deck because of overhang weight. Still able to lift.
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
207
161
Villa Rica, GA
I have a similiar set of 3 point forks. I modified the frame with a couple of 3/8" holes on the horizontal bar so I could bolt my chain harrow frame to them along with the chain hook on top. Works well.
BXHoosier
BX24
Jan 21, 2018
513
633
Indiana
I made a set of forks that hang over the top lip of the bucket. Then, I built a 3-point frame that the forks fit onto. The frame also has a 2 inch receiver hitch. I later added pin-on mounts to attach it to the loader. It gives me 3 different options to use the forks.
Oceandiver
BX2380
Mar 12, 2024
Southern Indiana
5,188
Well....Its time for me to finally finish getting all the useful attachments for my BX2380. I was at the kubota dealer inquiring about a rear blade and pallet forks. The BX can only lift like 600lbs maybe more with some hydraulic chicanery. So does the BX need heavy duty forks? I would assume not.
Is there a good set of light duty forks that can handle 600-800lbs of logs (or pallets)? Maybe save some $$$ and not have stupid heavy forks that take away from my lifting capacity? Most normal forks seem like overkill for the BX (again which including the forks can only lift 6- 800lbs.
Oh for the days of Everything Attachments!
Vince1230
Bx2370
May 13, 2022
159
77
Honey Grove,Pa
The ai2 and redline are lighter than everthing attachments when i was looking. Went with redline due receiver in frame. Did not have the long wait time like Ea. Good service from Redline. Weight was 162 lb for pin on bx. Ssqa was 177. Both 36 in forks.
EA website staes light weight forks 185 lbs.
AI2 are 162 lbs https://bxattachments.com/product/pallet-forks/
States bucket weighs 140 lbs
Bearcatrp
Mar 28, 2023
1,388
1,009
Minnesota
I have forks from redline for my 1880. Great light forks. Had skid steer forks at first. Way too heavy. The redline can lift up to 2000 lbs which is more than my 1880 can lift. You won’t go wrong getting these.
