Check the PTO lever to see if it might be engaged, blocking
Check the PTO lever to see if it might be engaged, blocking the engine from starting.
Also check the model number of your tractor, because, to the best of my knowledge, there is no BX2300 tractor. I guess that you meant to type BX23, or if it is a newer model, then it would be a BX23S. This model information is important because giving help is specific to the tractor model.
