Show off your homemade grill guards
GrassLakeRon
B8200HST-DP , RC60-82h Mower Deck, Woods RB6 Rear Blade, Homemade Carry All
Oct 27, 2023
318
190
Brooklyn, Michigan
Hi all,
I am hoping to weld one up this spring for my 8200. Would love to see some cool ideas from all of you.
Thanks
Ron
Papadiver
BX2380 FEL, MMM, 3rd Valve, Grapple
Feb 10, 2019
106
WV
It’s not a Kubota but it has a homemade grill guard!
Ron
Reactions: 11 users
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,673
2,120
Western MT
I bought a 5Eleven Designs. I like the way he used a single piece of metal. There are other brands that are similar. You probably could do something similar, too. I didn't because I felt like I had too many other projects to do.
I've also seen quite a few that used expanded metal or plate with holes in a frame of angle iron. They don't seem anywhere near as strong although anything is stronger than the plastic grill.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Hold on to your chairs, don't laugh to hard.
Well that’s a unique one. Keeps the front mounted hydraulic pump in jail.
OP if you do a search on this site for grill guards you’ll find an easy half dozen threads in the last year with pictures of lots of custom as well as commercial grill guard styles and options. I like my 5Eleven Desigz grill guard as well.
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
324
180
Eastern PA, USA
It comes off, I've had to rebuild the splined shaft on the PTO shaft. As you can see, it's taken some bumps in the past 70 years, but it's held up. That's 3/4" thick wall pipe, and pretty banged up.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Wait a minute. You let the PTO out of jail for bad behavior?😁
4,269
Here is mine before paint
Then I painted it.....but I ended up having to "trim a little off the bottom" LOL
Since I am "drill adverse" I am particularly fond of my "mounting system"
I made some "clamp style" mounts and used electrical tape and old inner tubes to prevent chaffing.
It's a little beat up now, so I guess it's doing it job.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
Well done on those clamps.
7,089
Made this a couple of years ago. Used "punch plate" drops. Had to use two pieces because that the size he had. Made simple hooks from "J" hooks. I rearranged the hooked end and put some rubber hose on the end.
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
My version.
