Show off your homemade grill guards
GrassLakeRon
B8200HST-DP , RC60-82h Mower Deck, Woods RB6 Rear Blade, Homemade Carry All
Oct 27, 2023
258
152
Grass Lake, Michigan
Hi all,
I am hoping to weld one up this spring for my 8200. Would love to see some cool ideas from all of you.
Thanks
Ron
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,353
1,780
Western MT
I bought a 5Eleven Designs. I like the way he used a single piece of metal. There are other brands that are similar. You probably could do something similar, too. I didn't because I felt like I had too many other projects to do.
I've also seen quite a few that used expanded metal or plate with holes in a frame of angle iron. They don't seem anywhere near as strong although anything is stronger than the plastic grill.
GrizBota
Apr 26, 2023
1,153
736
Oregon
Hold on to your chairs, don't laugh to hard.
Well that’s a unique one. Keeps the front mounted hydraulic pump in jail.
OP if you do a search on this site for grill guards you’ll find an easy half dozen threads in the last year with pictures of lots of custom as well as commercial grill guard styles and options. I like my 5Eleven Desigz grill guard as well.
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
309
141
Eastern PA, USA
It comes off, I've had to rebuild the splined shaft on the PTO shaft. As you can see, it's taken some bumps in the past 70 years, but it's held up. That's 3/4" thick wall pipe, and pretty banged up.
GrizBota
Apr 26, 2023
1,153
736
Oregon
Wait a minute. You let the PTO out of jail for bad behavior?😁
2,785
Here is mine before paint
Then I painted it.....but I ended up having to "trim a little off the bottom" LOL
Since I am "drill adverse" I am particularly fond of my "mounting system"
I made some "clamp style" mounts and used electrical tape and old inner tubes to prevent chaffing.
It's a little beat up now, so I guess it's doing it job.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
927
721
canada
Well done on those clamps.
5,559
Made this a couple of years ago. Used "punch plate" drops. Had to use two pieces because that the size he had. Made simple hooks from "J" hooks. I rearranged the hooked end and put some rubber hose on the end.
Trapper Bob
Jan 17, 2022
445
811
Andover, KS
My version.
