Still have it?I’ve got a Pto reverser for my B6000 and don’t know what to ask. I guess taking offers
NOT a good idea to post phone numbers here!I’ll check after lunch, it’s on a B6000.
can Pm me. Kenny
Thanks, never thought about that.NOT a good idea to post phone numbers here!
why are you parting with it?It’s 10 spline from the tractor and regular 540 out the back
I bought a tractor for the engine, it had the reverser on it and a finish mower. I won’t used it. I have other tractors to bush hog with. My B6000 is just a toy to piddle with and I’ve had it 20 years or so.why are you parting with it?
Is it a 4wd tractor? Would you be willing to part with the pro shaft as well? Mine is an 18 spline.I bought a tractor for the engine, it had the reverser on it and a finish mower. I won’t used it. I have other tractors to bush hog with. My B6000 is just a toy to piddle with and I’ve had it 20 years or so.
Parts tractor is a 2wd and everything is for sale.Is it a 4wd tractor? Would you be willing to part with the pro shaft as well? Mine is an 18 spline.
wish I had found you a few months ago, I just spent a fortune completely rebuilding the transmission. Unfortunately I don’t think the pto shaft will work in a 4wd unit, but out of curiosity, what do you want for the reverser and shaft?Parts tractor is a 2wd and everything is for sale.
I think your a little confused, there is no difference in the Tractors PTO shaft for a 2wd to a 4wd.wish I had found you a few months ago, I just spent a fortune completely rebuilding the transmission. Unfortunately I don’t think the pto shaft will work in a 4wd unit, but out of curiosity, what do you want for the reverser and shaft?
There is a difference between the 2wd and 4wd shafts, take a look at the transmission parts diagram. I have a gray model that came with an attached tiller, not 3pt, and has an 18 spline output to match the tiller. Us models had 3pt attachments and a 10 spline output.I think your a little confused, there is no difference in the Tractors PTO shaft for a 2wd to a 4wd.
His PTO spline is an 18 spine out of the tractor into the gearbox and 540 standard 10 spline out of the reverse gearbox.
Can you upload a picture of it and let me know what you want for it. I'm in Canada but I'm sure you can ship it here, if not I have a US address as well.Parts tractor is a 2wd and everything is for sale.
For the shaft I would need #68, 69, 70 and gear #28. If you don't have the parts diagram you can view it on Messicks website.Parts tractor is a 2wd and everything is for sale.
Where are you located and how much do you want for it?It’s 10 spline from the tractor and regular 540 out the back
Click on a poster's moniker and you will often times see where they reside.Where are you located and how much do you want for it?
