Rear Wiper electrical lead for sprayer use
DSR925
L3560HSTC LE
Jan 25, 2024
Ari040115
Hello! I am a new member. I have followed many threads on here and found the information very helpful. I have a 2020 L3560HSTC LE and added many components from information here.
I am seeking opinions on the use of the rear wiper electrical line for a 40 gal sprayer/boom rig. I would like to add a 3pt carry-all and use for spraying weeds on large food plots. I like the idea of not having a long lead from another point and inline switch that would be cumbersome to use. The ability to use the wiper switch to turn the sprayer on and off seems to me as a clean solution.
Any input would be greatly appreciated. Thank you!
mcmxi
6,335
NW Montana
So your sprayer has an electric pump rather than a PTO driven pump. You'll need to look at the amperage rating on the rear wiper circuit and compare it to the amperage draw of the sprayer pump. Both of those pieces of information should be easy to obtain.
I have a 55 gallon PTO driven sprayer with a 10ft boom but would like to have a bigger sprayer.
DSR925
L3560HSTC LE
Jan 25, 2024
Ari040115
Yes, it is an electric sprayer I had used on my ATV. Thank you for the advice on amperage.
Dustball
2016 B2650HSDC
Sep 15, 2023
294
171
Hudson, WI
The wiper switch will be switching the ground side of the wiring, not the positive side. Keep that in mind when wiring.
mcmxi
6,335
NW Montana
This is the wiper wiring schematic for my M6060 so take that for what it's worth. It shows a 15A circuit, and when the switch is turned ON there's 12V provided to a relay in the wiper motor via the Light Green & White (Lg/W) wire. When the relay trips it connects the + side of the motor to the Blue (L) wire which is the 15A source, and the - side has a direct path to ground with the Light Green & Black (Lg/B) open circuited by the relay. Well, that's how it looks to me. A multi-meter is your friend in these situations.
4,908
I've used the 4 channel RF realy modules, about $20 cdn for years.
Fed power from bullet connectors on my BX23S by 3PH, controls LED headlights AND garage door opener. Still have 2 spare relays for future uses.
It'd just be 'wrong' to hack into the rear wiper of your cab.
Velcro the keyfob somewhere ? I hang mine on the cruise control rod.Easy enough to get to.
DSR925
L3560HSTC LE
Jan 25, 2024
Ari040115
I was thinking that I could use a proper connector that is on the wiper motor and control it with the wiper switch. My front wiper does not have a delay and is either on or off. I assume the rear wiper would be the same.
pokey1416
Jun 24, 2020
556
825
SW Michigan
4,908
can it be done, sure, but you'd have to unplug/plug in the connector every time you want to use the sprayer.
now that could be a real pain, feeding the sprayer connector through the cab, up to the WW motor location.
also no mention yet of the AMPS the sprayer needs. it could exceed the contact rating of the WW switch ! Bet that switch aint cheap to replace. YIKES, just checked...
No code has to be inserted here.
is $108 Cdn $$ !!!
For $5 CDN I can turn the sprayer pump on/off AND no ugly modifications to the $2800 wiring harness in the cab.
But, in the end, your tractor, your decision.
Workerbee
Zd21
Mar 1, 2020
204
91
MN
Those little fimco pumps dont take much amperage. The factory harness that comes with them has an inline switch, and it isnt much. Probably half as sturdy as that ws switch in your Kubota. I wouldnt hesitate to do as you are thinking, hook it to the factory ws wiring.
4,908
'fimco' pump ? I didn't see the OP say that was the make, let alone a model number.
i know the pump I have draw a solid 8 amps when running.
DSR925
L3560HSTC LE
Jan 25, 2024
Ari040115
I talked to the service department at my dealer. In my LE the is a power lead under the seat that work when the engine is running. Under the rear window there is a grommet that a wire (with an inline switch) can be run thru. They said the wiper line should handle it but they cannot get a matching plug for the wiper power line. And it would require a wiper switch
thank you all for your ideas and input.
