B2400 popping out of 4x4
moose517
B2400
Jan 6, 2024
12
B2400 popping out of and will not stay engaged in 4x4 also still grinding noise in high range
Any ideas????? Losing my mind
3,328
Worn 4WD coupling (this is a female, sliding coupler on the drive-shaft between the trans and front axle..)….. OR…Worn or Mal-adjusted linkage between the 4WD selector knob/lever and the coupling.
moose517
B2400
Jan 6, 2024
12
Just seems weird that it didn't do it before we split tractor to change a seal like it will barely engage in 4x4 u have to hold the lever and will shake the shit out of ur arm
3,328
Well….splitting the tractor may also have changed the clearance/engagement of tha coupler and may be contributing to the new problem.
moose517
B2400
Jan 6, 2024
12
Ya my stupid ass when I put it back together I figured I had the yoke for the front drive shaft on all. The way the hole for the roll.pin was good roll pin went in and was working but had a noise n vibration right from the start so needless to say I'm a dummy and now we need a new yoke....
