Diesel can fit
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
447
701
NH
I know this is a trivial post, but discovered today that a 5 gallon gerry can of diesel fits perfectly on the step of the L6060. Does require keeping a knee pressed up against the can while using battery pump to fill the tank. Sure beats trying to pour by hand in the cold.
5,187
Unimportant general info:
"Jerry" cans were used by the German military in WWII, and their design was then copied by the USA.
German military members were referred to as "Jerries".
Thus the slang name used by our Allied military for the German fuel storage cans was "Jerry cans".
Gaspasser
Dec 16, 2023
447
701
NH
Thinking that's wherec the term Jerry rigged came from as well.
4,184
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
And jury rigged comes from an old nautical term for a cobbled up temporary mast to solve a broken mast problem.
GrizBota
Apr 26, 2023
1,147
733
Oregon
The was a fellow who was a diesel fitter. He always came home from work nice and clean, smelling good and had soft hands. His neighbor doubted that he was actually a diesel fitter. So the neighbor followed the fellow to work one day and watched the fellow work. Turns out the fellow worked in a textile factory and inspected women’s undergarments. He’d hold them up, take a look and announce “ ‘dese ‘ll fit ‘er”, and sort them in to the appropriate sized bin.
On my tractors, which have the fuel filler on the top, through the hood, I set the can on a rag and use a cheap D cell power battery to “pump” the fuel into the tank. Getting older is glamorous. But I don’t suppose I’ll have much chance of bumping the fuel tank into a stump or such.
jaxs
B1750HST
Jun 22, 2023
1,065
803
I was doing just fine with fuel cans before lawyers and government forced mfgrs to "IMPROVE" them. Now I spill as much as goes in tank and get a bath.
jaxs
B1750HST
Jun 22, 2023
1,065
803
A company could have a whole line of products with Middle Eastern troop nicknames.
Bmyers
May 27, 2019
3,624
4,907
Southern Illinois
I thought that term came from the courts in Chicago, learned something new. :p
7,619
Interestingly the criteria for the fuel can was, could withstand wear, pour well, store conveniently and carry easily. That was 1937. With our government coaching/insistence we've mucked it up several times and continue making it "work".
4,184
Let me guess. The woke crowd will now consider that name racist!
Well,… by ANY definition…it IS pejorative…as is some use of “woke”….. . but since the Nazi Germans were defeated it has been accepted in western vernacular. .
Gaspasser
Dec 16, 2023
447
701
NH
Agree. Hate trying to juggle a heavy can while trying to depress "safety" valve to allow flow while trying to keep spout on target. I take cap off completely and use D cell battery cheapo pump from Harbor Freight.
11,758
Supposedly the term Jerry (to mean a German soldier) was coined in WWI by British troops who thought that the German helmets looked like chamber pots.
11,758
I have to stand on my front tire to fill up my M59. Makes a lot more sense then filling at ground level. Way to go Kubota!
I have a John Dow 106 gallon fuel storage container but often find myself needing to go old school when fueling up the MX6000. At the house I use a step ladder (one foot on the front tire, one on the ladder), a funnel and remove the fuel container cap to make it go as fast and as safely as possible. When I'm away from the house there's really no option other than to do a balancing act.
I should probably look into good (safe) fueling options when working away from the house. One of those fuel caddy hand pump type of setups. Maybe something like this with the optional rotary fuel pump.
Gaspasser
Dec 16, 2023
447
701
NH
Yep, saw those. Pricey when compared to Jerry can though. Guess I can have convenience or money in my wallet, but not both, lol. As mentioned, raising can up ( step ladder, pallets ) could work with siphon. Or maybe raise can in fel bucket and then siphon with long hose? Build a shelf on a nearby tree and pull up to it? Or go to gym for six months and build up muscle strength?
5,187
Fill can 1/2 full
Get several spare cans.
Fill cans only 1/2 full.
Much easier to deal with.
11,758
Some things are worth the cost of convenience, and when they reduce the chance of injury it's easier to justify the expense. I'll probably order a couple of those fuel caddys at some point and replace the six 5-gallon diesel containers I haul around in my truck. One transfer pump would be enough, and 50 gallons of fuel for road trips or off property tractor work would be good. I could load the 106 gallon John Dow tank onto a trailer but I simply don't need that much fuel with me.
4,116
2,811
I rent a diesel storage tank from my fuel supplier - $100/year for a brand new double walled 500gal tank with electric pump and filter. Not worth screwing around juggling jerry cans, I would need two to fill my tank.
