I have a L175 and the RPM gauge does not work.
Lpalmer
m7060 & L175
Dec 27, 2021
10
Maryland
hello,
i have a L175. The rpm gauge does not work. the cable has been replaced. any ideas? Thanks,Larry
5,257
1,047
First remove the cable from the instrument and run the engine to see if the cable inside is rotating.
If it is then connect the cable back to the tach and connect a drill to the far end of the cable to see if you can make the tach needle move.
If all else fails look for an automotive instrument repair shop in your area as car restoration people use them all the time.
Contact forum member 007kubotaguy who is often parting out old L series and may have a good tach.
dave
Lpalmer
m7060 & L175
Dec 27, 2021
10
Maryland
dave
Dave, Thank you very much! Larry
2,402
hello,
I recall that the engine part of the tach drive was a problem on these. The gears would fail or something. So if the cable is nor spinning it is probably that driver. And I think that is an obsolete part.
Lpalmer
m7060 & L175
Dec 27, 2021
10
Maryland
I think thats the problem with mine. do you know if they call it a "case ,gear, assy/ hour meter"? found a part number 1G633-83302.
2,402
Here is what I found on Kubota USA Ilustrated Parts list but see new part number from Messicks below
I have no idea what the part number you stated is. I can’t find any pictures of that part
2,402
Yes that looks like the tach drive for some engine that is similar to what you need.
Kubota showed two part numbers based on the tractor’s serial number. Then I searched for one of them and Messicks converted it to a similar number as yours.
Yours seems to be for larger engines
The one I found mentions the L175
I think you should get Messicks or your local dealer look for the correct one so they will need to have the serial number or they may end up having two numbers to choose from without the serial number.
Lpalmer
m7060 & L175
Dec 27, 2021
10
Maryland
Thank you for all your help! i will call Messicks.
2,402
Good luck, I am glad that part is coming available again!
Please post back with what you find out.
If you don’t mind asking Messicks about why the part number starts with a different type of sequence than most of the Kubota part numbers.
Lpalmer
m7060 & L175
Dec 27, 2021
10
Maryland
Absolutely will do!
MGnoob
L175
Aug 27, 2025
22
Massachusetts, USA
Did anyone order the part? Has anybody ever disassembled one to see if it can be repaired?
I’m not sure if mine works. I don’t see it visually spinning, but I’m not sure if that’s just the end of the cable that’s broken off in there. I didn’t wanna take it apart without checking with you guys. I’m not sure if bunch of oil comes out or what happens..
Photos worth 1000 words.. I usually always say pictures or it didn’t happen though.
Be sure to run your drill counterclockwise.. I can’t seem to post a video but it appears I get a reading about 1800 RPMs on the number two setting of my Dewalt drill
2,402
I have not needed that part so did NOT order it.
