Loader problem
SD1955
BX2380 LA3444 loader 54"belly mower
Jan 10, 2024
Orwell VT
I lhave a BX2380 with a LA3444 loader. Only 50 hours on the unit. While pushing snow, I heard a "pop" and the loader would not raise or lower, and the bucket won't tilt. No response from any position of the control lever. I checked all the lines and can find no leak. Oil level appears to be fine. Three point hitch raises and lowers. Any advice on what to look for or what might have gone wrong. Thanks.
imnukensc
BX2380
Sep 10, 2015
784
752
Midlands of SC
How does your joy stick feel after the "pop?" The same? Different? Pull the rubber boot up and take a look in there. May not solve your problem, but won't hurt to take a gander at the linkage.
SD1955
Jan 10, 2024
Orwell VT
1704989164152.png I
I can't detach the hydraulic couplers due to the location of the release handle against the lifter arms. Is there a way to move and detach the lifter arms without the use of hydraulics? Thanks,
SD1955
Jan 10, 2024
Orwell VT
What are you trying to accomplish?
Lifter wont respond to control lever. No visible hydraulic leak. Recommended fix is to remove couplers and reseat to see if there is a leak. But I can't move the handle due to location next to lifter arms.
6,961
While that might be the problem I doubt it. My guess is the joystick linkage is not working. Remove one of the hoses from the coupler, put the end in a clean can or bucket, and see if you get any oil out of it when you operate the joystick.
Whoops ' the oil wont be out the hose - it will be oit of the coupler.
Jsjac
B2650
Feb 13, 2022
239
386
I would say from your description it is not the quick couplers.
Sounds like maybe the joystick part failure.
I did not see you say if the joystick feels the same or not.
Does the three point hitch work?
Alfred_2345
L3901, LA525, BH77, SGC1060, RZ60, Box Blade, Z726XKW ZTM, RTV-X900
Jan 5, 2023
134
65
Northwest Arkansas
The reason folks are asking if the 3pt hitch works (lifts) is that is at the end of the hydraulic circuit.
Note: 3pt hitch lowers under gravity (i.e. not powered) and you have to have the lowering speed control valve open (usually round knob under the seat).
If the 3pt works, then the tractor hydraulic is OK and the problem is with the loader....
Bearcatrp
Mar 28, 2023
1,311
956
Minnesota
Had this happen on a old skid steer. The piece between the motor and the hydraulic pump broke. I was lifting more than I should have. Don't know if this is the same on tractors but worth a look.
6,246
I'd move the loader frame lever to the 'unlocked ' position...
unlock the 4in1 coupling lever..and then lock it down.
I suspect it's not properly seated.
On my BX23S that lever is horizontal, yours looks 'up a bit'.
SD1955
Jan 10, 2024
Orwell VT
Thanks. 3-point does rise and lower.
5,160
It is in the loader control. Open it up and look around for a clip the has fallen off. It happened to my BX22 and drove me crazy till I found it.
6,961
Before you get too carried away just look here and verify this clip is still in place. If it comes loose the joystick will not operate the spools in the control valve. It looks like all you need to do to inspect that is remove the the rubber boot on the fender. My guess is it has a molded lip on the bottom edge that engages the hole in the fender. Gently pry it loose and slide it back up the joystick to expose the linkage.
5,160
so the joystick moves 'normal' , left right fwd back ??
the 'pop' might have been the ganged coupler 'popping' up as it wasn't latched properly.
The coupler is a black-and-white type of operation. It is either clipped on correctly, or it will not stay down and operate the loader. Unless the coupler has been modified or the locking pin has been sheared off, it is either coupled or uncoupled, there is no in-between that will work for one minute!
6,246
it may be the picture but it looks a bit 'off' from the handle position compared to mine. Mine is horizontal, his looks 'up'.
zero operation of the loader points to the coupler of the joystick(maybe joystick is locked ?'
mor einfo/pix are needed
6,961
It would take no more than 60 seconds to pop the boot off the joystick and verify operation of the linkage. Instead this thread has dragged on for days.
6,246
The boot for my BH came off in about 3 seconds....now replacing it too a LOT longer.....:) After 5-6 minutes I FINALLY clued into HOW to do it in less than 30 seconds........
it'll be nice to hear WHAT solves this thread......
SD1955
Jan 10, 2024
Orwell VT
Problem solved when I was able to move the connection lever to the correct position (used a metal rod to lever it down).
Thanks for everyone's thoughts on this.
