6,897
What is the green line?
Hahaha. That is the main stack (cast iron). This home was just recently purchased and the original owner had painted all of the plumbing lines in different colors. I should've taken a picture of the pipes in the basement. he painted the hot water lines in red, blue for cold, waste in green. It was quite a colorful basement.
The top most line in pic number three turned out to be an electrical conduit run in galvanized pipe containing 2 live lines...we found that out after cutting thru half of it (we assumed that it was the water line going to the garage spigot). Nope! nice sparks while using a band saw. :mad:
lakehouse_dreaming
L3901HST, LA525 FEL, RGA1258 tiller, RCR1860 rotary cutter
Nov 2, 2021
59
125
Today was leaf day. Three houses with gutters to clean, three yards, trails, whatever you call the clearing in front of the shed, etc. Leaves everywhere. Some places a little grass still visible; some places 10” deep.
Leaves. View attachment 117766
More leaves. View attachment 117767
MORE LEAVES! (I don’t much like this particular chore.)
Joint project for the L and T. Got up about 90% of the leaves with the rake and grapple. Piled them up in several large piles. View attachment 117769 View attachment 117770
Once it was down to a thin enough layer for the T to mulch/blow it, finished with the T. View attachment 117771
Stihl blower played a small, but crucial, role as well. It has been camera shy since I ran over it with the Tundra last year. Works great, but kind of looks like it was run over by a small truck.
Edit: Just noticed the pic with the rake is one of, I think, 4 times I straightened the tines because they were too gap toothed to work right. When the tines spring back the circle at the 90 opens so I was thinking of threading some sort of pipe through the hole to further limit their rotational range of motion. 🤔
Who makes that pine straw rake?
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
268
486
Moseley, VA
Another day clearing up the old fence lines on the property. Loaded all up and to the scrap yard for about $115 return but at least I did not have to pay to dump it. Approximately 1600lbs of old t-posts, woven wire, barbed wire and a rotted out old hay ring. The electromagnet on the boom of the loader at the scrap yard takes about 2 minuted to off load everything. All in all a good days work with enough cash to pay for fuel.
7,573
Man, you never have a dull moment!! I thought maybe it was the downspout being dumped in there. ;)
5,186
fruitcakesa
M4 071
Oct 26, 2010
879
304
Cavendish Vermont
Put the chains on the M and hooked on the box blade in anticipation of the predicted snowstorm tomorrow evening. I will put the plow on tomorrow after the final weather report in case it’s not needed.
g_man
Feb 3, 2023
378
1,767
NE Vermont
Started pulling out firewood again after the long wet thaw between Christmas and New Year has finally started to freeze up again.
gg
Reactions: 6 users
OntheRidge
Nov 1, 2020
492
583
Got the plow on and greased in case we actually get snow tomorrow. Love this tractor but really wish 20240105_130307.jpg 20240105_131325.jpg it fit in garage. Future project.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
395
540
SE, NM
Did this Monday, just now getting to post. Used the grapple to move 3 60" Oak logs. I normally cut them 80", but I had to back up the hill a ways to get them out. Don't think I would have made it at 80". Had the ROPS up and the seat-belt on for these three.
I hope nobodys hand was in that glove when it got caught:D
L35
Jun 13, 2010
703
827
CT
One of this years projects was to refurbish my old plow. The skin was rotted out so I found a place in PA that custom makes them. I then sandblasted, reskinned and repainted everything. Today I bolted on the cutting edge and mounted it to the tractor since starting the project. We are expecting up to a foot over the weekend.
5,162
I got the loader off put it away and then installed the K connect driveshaft and snowblower. OK, I am lying, I had help putting the K connect onto the tractor and installing the driveshaft. I did put the snowblower on myself and hooked everything up even though I was feeling lousy. I still have to put the weight box on the 3-point hitch tomorrow, but that shouldn't take much effort. I used to love snow blowing and plowing, but now in my later years, I am beginning to detest it. Still, have to move some tings around in the garage to get the wife's car in there. She doesn't like cleaning snow off of her car, but I have no idea why.
Old_Paint
Dec 5, 2020
2,003
2,239
AL
View attachment 119514 View attachment 119515
Love the old pump by the garage door. Would love to have something like that to put out by my shed. Where'd you find it, and how much (ballpark)?
5,186
They are available on E-Bay......$2,500 and UP!
Old_Paint
Dec 5, 2020
2,003
2,239
AL
Umm, maybe a bit more than I want to spend on a decoration. If it were functional, maybe, but not just an ornament for that price. Thanks just the same.
