L02 series seats for L01 series tractors
TGKY
L4701DT
May 24, 2018
116
38
US
Will the seat from an L4802 fit an L4701? I would love to upgrade the seat on my 4701.
Thanks in advance.
5,564
If yes, I would like to know if the L4802 seat is really an upgrade.
TGKY
L4701DT
May 24, 2018
116
38
US
I for sure don't know first hand, but the driver for this post was this snip from the kubota site. How relative the term "improved" suspension is, I don't know lol.
5,564
At least it has arm rests. Otherwise the seat itself looks similar. If I see a L4802 on a dealer lot, maybe I’ll see if they’ll let me test drive it so I can run it over a curb or three to test out the “improved” suspension. If it will run over a 4” curb at 3mph without bottoming out and sledge hammering your spine, that’s an improvement.
One good thing about the stock seat on the 4701 is it probably increases the durability of the tractor. If you’re about to run through a hole or over a log, etc. that seat is strong encouragement to do it slowly and smoothly.
ajschnitzelbank
Aug 24, 2021
268
669
Rensselaer County NY
Haha I never thought about the terrible seat that way before. Thanks for helping me see the bright side!
ken erickson
Nov 21, 2010
1,333
2,367
Waupaca Wisconsin
Spot on and thanks for the chuckle! My L2501 seat accomplishes the same.
drumminj
L4701, Mule 4010
Nov 4, 2021
156
119
TN
I did test out an L4802 seat a few months back, and it would be an upgrade. Much cushier.
I inquired with Messicks a while back..the part would be $542, but they couldn't confirm the bolt pattern is the same/it's a simple swap. Would love to confirm if it is.
PaulL
2,678
1,670
NZ
Neil from Messicks did a video a while back on adjusting the seat - turns out many of these machines have an adjust to stiffen the spring for larger guys. Worth checking that about yours before replacing it.
5,564
It does have adjustment for the spring tension on the suspension as described in the OM above.
PaulL
2,678
1,670
NZ
The L01 seat has an adjustment, or the L02 does? I assume L01. Worth adjusting that to see if it makes a difference if so.
5,564
L01. I know nothing about the L02 other than it’s the latest iteration of the L4701.
The L01 seat suspension consists of a pair of springs. The T handle thing shown in the L4701 OM excerpt above (sorry, I just noticed the “L4701” didn’t show in the page) is a screw jack sort of adjustment that changes the pre-tension on those springs. The heavier the operator, the tighter the pre-tension should be set. So, yes there is some adjustment for the spring action. I’m about 220lb so mine is set quite tight.
IMO the basic issue with the seat suspension is there’s very little travel so it has a tendency to bottom out more easily than the Fords, Longs, IHs, Deeres, and Masseys I’ve operated in the past.
If I could get a moderate improvement for $250 or less, I’d probably do it. $500 or more, definitely not even if it made it ride like a cloud. Hopefully that explains how much it actually bothers me. If I REALLY hated it or it was causing me physical problems, I’d be looking into a Grammer air ride even if I had to make significant modifications to mount it.
