7,007
I paid close to $200 for the return filter on the SVL when I completed the 250hr service. I didn't drain my resovior either after talking with a Sr. Kuboter mechanic on how he does them. I agree those prices are just stupid, and after inspecting the old filter, I don't plan on changing it until 1k hours. I do plan on changing the regular $80 hydraulic filter every 250hrs vs the 500hr interval though.
I believe that the suction filter in the tank is serviceable (at least once they say) but not the return filter....?
I do have 5 gallons (unopened bucket) of hydraulic fluid for the mini (the good stuff) from when they came to fix my leak on a brand new machine....so, there's that I guess.
I'm planning on doing an engine oil change at 250 hours (soon) instead of at 500 hrs. That's just too long (to me) for a first engine oil change.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
I did the same at 250hr with engine service! Totally agree, supposedly the construction equipment has more advanced engine break in, at the factory compared to the tractors from what I was told.
The return filter does have pleat type fabric(iirc) in it, look at your new one.
The suction filter might be all metal, if so, I will give it a good cleaning.
11,757
I picked up 8,500lb of firewood today and used the M6060 to move the trailer up to the house. It was a bit sketchy with insufficient weight on the front axle despite 816lb of suitcase weights up front. I backed the trailer up a steep hill to prevent the front of the tractor from lifting too much. The trailer as shown weighs around 14,000lb.
Pulling from a ball on the draw bar would be better, but the trailer tongue and lift arms don't play well together.
The tractor is a "tank" and had no problem at all with the load in terms of moving it around. Maybe the front wasn't as light as I thought it was, but it felt light to me. I don't know. Anyway, the wood is up by the house and all is good.
Reactions: 11 users
matt-m
2022 B2601
Mar 17, 2022
82
449
53
Columbus, IN
Needed an excuse to build something no oops I mean a place to store implements more out of the weather / help free up space in the barn.
Reactions: 23 users
ajschnitzelbank
Aug 24, 2021
271
700
Rensselaer County NY
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
View attachment 119084 View attachment 119085 View attachment 119086
Very nice!
What size are the horizontal beams? The ones holding up the BB and grapple.
I've been wanting to do something like this eventually. Just not sure how big the beams need to be to hold stuff. Your grapple looks like a heavier duty one, as is mine. I appreciate any insight.
pokey1416
Jun 24, 2020
572
885
SW Michigan
Ok so the Mrs got me a spinner for Christmas, this is the only way it sits somewhat right that I can see. I told her I’d try it out as I’ve never used one. I understand the wheel changes position so it won’t stay at 10 o’clock.
Which way do I need to rotate this thing?
matt-m
2022 B2601
Mar 17, 2022
82
449
53
Columbus, IN
Wow nice. I’ve been thinking about something similar. Looks very well made. What are the corner posts? (More than one piece of wood screwed together?) What are the post footings, did you pour them or get them precast?
Very nice!
Thanks guys. Disclaimer that my projects usually have something that’s not ‘necessary’ or ‘normal’ but the O.C.D. / sense of aesthetics takes over.
The posts are screwed on to 4x4 exterior grade post brackets and those brackets are center bolted down using threaded j-hook concrete anchors. The brackets sit on / anchors are in concrete using sono tube forms (hand dug post holes for the tubes with carried in, mix on site style concrete bags.) I’ve had good luck with this approach over the years for keeping posts secured and the ends dry. But yes like any post setting you really have to be exact with your j-hook placements to have things be square and get the spacing you want.
The corner posts have been face clad with treated 1” x 6” or 1 x 8” ripped to needed widths is what you are noticing on appearance as something more than typical 4x4 (with sections of 2”x4” “filler” added on the posts between where the horizontal boards attach and before the 1”x went on.)
Yeah I debated what to frame the pallet shelf with. I ended up using 2”x6” lag bolted on after doing some figuring (admittedly it’s hard to shake the default of something more like a residential floor or deck.) It didn’t complain a bit when loaded up, but I certainly wouldn't fault anyone going a bit stouter. It’s tractoring so there’s always the chance for ‘unintended events’ that could make a mess of things. One preventative I do is when I’m setting a load (particularly the grapple) on a shelf is I’ll turn the tractor off once I’m ready for placement. This way I can drop the load down via hydraulic release but I can’t accidentally ‘push down’ on the shelf. Bit of overkill maybe but so far no regrettable moments. I’m thinking hard on a wood chipper is why I didn’t go full width on the shelf and left a full height opening on the one end.
Old_Paint
Dec 5, 2020
2,047
2,333
AL
Only difference in your spinner and mine is mine is black and "Kubota" less (no logo). Same thing, tilts inwards slightly and a little funky to get used to, but I don't notice it so much anymore. Makes quick steering easier, but in tight quarters where small steering changes are required, not so much. It would probably be a lot more useful doing field work (turning at the ends). But it's still a nice add-on.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
Awesome! Thank you sir!
