Love it. Do what makes you happy.Thanks for the input.
I have always been a bit concerned about the coolant pump with no stat in it. But it keeps temps at around 85 degrees when under heavy load for long stretches.
as said The oil filter relocation is purely to help make it easy to change it. I will think about a good location where it is away from danger. I found this a better option than butchering the side panels. The tractor has a hydraulic pump at the front with a guard up front as well. I can add to it to protect the filter.
with regards to the oil cooler which is quite small in size, Malta is a bit hot and temperatures are rarely under 15'C I used to give it 15w40 engine oil but I have a drum of 10w40 diesel truck semi synthetic oil which is i could use in the D850 once installed.
i just over think my way through life I know. I need a little project like this because I am growing really dull
At my house the temperatures range from -30°C to +35°C, but I don't have to do tractor work when it's too hot
