Type Of Injector System - L2500
Coupland350
Kubota l2500
Nov 22, 2023
Elgin, Texas
How do I know what Injector System I have on my 1999 L2500, with a 3 cylinder D1403 engine? Is it a CRDI (Common Rail Diesel Injector), Direct, Indirect or something else I never heard of? I'm so confused it ain't funny. I've attached some pics of my injectors if that helps.
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
259
169
WNY
Indirect, PLN pump line nozzle
10,984
The exact answer can be found stamped to the block just to the side of the injection pump facing up.
There are a LOT of knock off Injectors out there and most are junk.
Spend a little more and get a good set.
Coupland350
Kubota l2500
Nov 22, 2023
Elgin, Texas
Would that be this number in the pic I've attached? I thought this number was just the engine / date code.
I'm trying to determine if one of my injectors is not working properly. The closest place to have them checked/tested is 30 miles away and they want $50 per injector to test them. I was going to buy a tester online for under $100 and test them myself. The tester information states is doesn't work for CRDI injectors. I know they are working but I don't know at what PSI that are opening/popping or if the spray pattern is correct. I have an engine knock that developed and I'm trying to eliminate the injectors.
Here's a link to the tester in case you're curious.
VEVOR 400Bar 6000PSI Diesel Fuel Injector Tester Diesel Injector Nozzle Tester with Dual Scale Gauge to Adjust Injector Nozzle Pressure and Testing Diesel Injector Nozzle Pop Pressure Tester | VEVOR US
10,984
Yes that's the engine type and serial number.
D1402 IDI engine
While the tester will give you pop pressure it won't do much else for you.
You can easily see the spray pattern by hooking up an injector off to the side of the engine.
Use a piece of cardboard to see it NOT any part of your body!
Coupland350
Kubota l2500
Nov 22, 2023
Elgin, Texas
D1402 IDI engine
I appreciate your feedback. Gotcha on the body parts!
