I bought an ATI Tach-All for my MX5100 and its LA844 loader to convert it to SSQA. It looks really well made but for some reason one of the bottom pins doesn't align with the ears. It is off center by at least an 1/8". I tried removing it and the other bottom pin to reverse the order. Sure enough the one I struggled with before went right in but now the other side has the issue. The pins came out of the old bucket no problem and the bucket nor the pins appear bent. The pins go into the new adapter easy enough without going through the loader arms. Either the loader arms are bent or this thing is not made right. Even if I could get it in there it seems like it might wear on it uneven. Thoughts?
