Same diameter tires as what came off. all is good"
"Fitting" and "working" are 2 different things.
Folks smart in the mechanics of all things 4WD can tell you about the bad things that *MAY* happen if you change the tire diameter.
Did not ever mention that I am changing the tire " diameter" just the hole size."
I did, Carlisle turf 18- 8.50-8 to Carlisle Versa Turf 18-8.50-10 And the same for rear Carlisle turf 26-12-12 to Carlisle Versa Turf 26-12-12. All that is different is A "smaller hole" to A "bigger hole". ALL IS GOOD.It has been proven on these forums that tire diameters can vary within the same manufacturer and tread type from tire to tire. Make no assumptions that all tires are created equally. Check the diameters once the tires arrive before mounting. Then inflate equally and check the diameters once again. If there is a more than 1/4" variance, I would ask for another tire and send one back after the new one arrives.
