Bx1500 Front End Loader pin keeps falling out
joesmith123
L295DT, BX1500
Mar 18, 2023
530
136
earth
Left pin keeps falling out
What is the mechanism that is supposed to hold it in place?
I see there is a hole in the pin, I put cotter pin inside and hammered into its hole, hoping that would hold it, didnt work
The center of the pin is more narrow, maybe that is for securing it in place
The pin can go in from either side of the hole pretty easily
Suggestions appreciated
2,551
Is there a hole where the red circle is?
How does the OTHER side stay put?
There should be a bolt that goes through the welded boss and through the pin - much like in these pictures of a BX1500
cthomas
LX2610 HSDC
Jan 1, 2017
865
579
La Farge Wi
The groove in the middle is for grease to be distributed when/if you grease your loader. At the end of the pin find a bolt that fits and locate the same hole on the bucket, install a bolt with a little blue loc-tite on the nut.
joesmith123
L295DT, BX1500
Mar 18, 2023
530
136
earth
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,185
877
PNW-WA
There's something with tractors, their maintenance or upkeep. About every aspect happens in pairs, or x2.
5,238
Fixed
I did notice other side also needs pin
but now i go back and level land
Probably OEM is an appropriately sized hex or Allen head bolt with a nylock nut. Don’t want it tight, just thread the nut on and leave loose.
5,066
Fixed
That "hairpin" clip is a poor idea, because it CAN get pushed out.
It will work,..... but as others suggest, - a bolt with lock nut - is a MUCH better idea!
Ask me how I know this!
2,921
1,383
Fixed
It does not matter what you use to retain the pin if you are not greasing them, they will keep shearing the retainer and fall out. You need to get a grease gun and use it regularly.
