Oil pressure
Adam Wesley chambers
Kubota 3560
Nov 22, 2023
Georgia
I have a 2014 kubota grand l 3560...it had been sitting for about 2 weeks..I started it up and it threw me a oil temp sensor ng alarm...was told to reset it and see if it came back...I did that and it came back...any advice on where it's located or what to do without taking it to the dealer
Bearcatrp
Mar 28, 2023
1,384
1,006
Minnesota
Oil level good? Oil contaminated?
6,308
I wouldn't think Georgia would be that cold ,though they have had chilly weather in the past.
What temperature does the alarm go off at ? Is the display a constant xxx degrees or does it go up when engine gets warm ??
Mice are NOT 'tractor friendly'......
Kubota 3560
Nov 22, 2023
Georgia
It's been warm all year...its was around 80 degrees when it did this and I had only been running it literally maybe 1 to 2 minutes...engine temp hasn't even had time to come up
cthomas
LX2610 HSDC
Jan 1, 2017
866
576
La Farge Wi
Get a WSM and start checking wires, I suspect something has chewed the wiring.
5,164
86 Error Code For Kubota Tractor Models
There is 1 kind of error description.
Description:
Wheel Slip Signal is failed in the Instrumentation Controller
Partial frosting and sweating of lines combined with poor cooling, fan belt slipping, loss of refrigerant, restricted or clogged liquid line or expansion valve malfunctioning.
