I think I did it twice on mine (same as your machine). But I had it for 12 years. It's the vibrations (especially at idle) that does it. I went thru several air filter brackets too for the same reason. Gave up on them and just used a bungee on the A/F. It was still working well when I traded the machine in.I will be putting the third muffler on to my BX23 soon. It just falls apart at the bolt flange end.
700+- hours on the machine. Just seem to not be lasting!
o.I sometimes think that some owners are afraid of the throttle lever. The vibration of the little 3 cyl engine at lower speeds is pretty severe, enough to break mufflers for sure.
it needs to run some RPM. 2500+. This also helps keep some moisture that is a normal byproduct of the combustion of diesel, boiled off and expelled.
So..ooo....is the 4 cyl engine better?I sometimes think that some owners are afraid of the throttle lever. The vibration of the little 3 cyl engine at lower speeds is pretty severe, enough to break mufflers for sure.
I think the shutdown event is the most violent.I sometimes think that some owners are afraid of the throttle lever. The vibration of the little 3 cyl engine at lower speeds is pretty severe, enough to break mufflers for sure.
4 cyl is WAY smoother. Inline 6 is the best. Many years ago I bought a new 300 cu in straight 6 Ford F150 and manual trans. Things was amazingly smooth, quiet and torqueyS
o.
I have both a Shibaura 4cyl, and Kubota 4cyl.
I have never run either engine at "2500+",
Both have original mufflers, and relatively little vibration.
Does the 4th cylinder make that much difference in smoothness?
I still have my 1977 F-250 4x4 with the 300 six, and manual transmission....bought new.4 cyl is WAY smoother. Inline 6 is the best. Many years ago I bought a new 300 cu in straight 6 Ford F150 and manual trans. Things was amazingly smooth, quiet and torquey
My standby generator is a Lister Petter 4-cylinder diesel that spins at 1800 RPM. You could stand a nickel on the top of that engine while it is running. My Mercedes diesel wasn't as smooth running. I believe that it is the brand of the engine that also factors into the equation.S
o.
So..ooo...................
I still have my 1979 F250 4X4 with a dump body installed. It hasn't been used in more than 20 years, however, last fall I got it out and refreshed the brakes, oil change, battery, and fresh gas, and it ran as well as when I stopped using it 20 years ago. Unfortunately, the clutch didn't fair as well and after a couple hours of use, it gave up and had to be pulled back into its 20-year resting place. If I can find some help I will pull the transmission and transfer case and put a new clutch into it. I stopped using it because the rear cover on the differential got torn loose at the bottom and the gear oil ran out and ruined the rear. It is OK for slow-speed use, and I purchased a replacement 20 years ago but have yet to install it. That also is on the list of future repairs.I still have my 1977 F-250 4x4 with the 300 six, and manual transmission....bought new.
I've got a lotta old stuff....including me!
I actually "gave" my 77 F-250 4x4 to my oldest son, 20+ years ago.I still have my 1979 F250 4X4 with a dump body installed. It hasn't been used in more than 20 years, however, last fall I got it out and refreshed the brakes, oil change, battery, and fresh gas, and it ran as well as when I stopped using it 20 years ago. Unfortunately, the clutch didn't fair as well and after a couple hours of use, it gave up and had to be pulled back into its 20-year resting place. If I can find some help I will pull the transmission and transfer case and put a new clutch into it. I stopped using it because the rear cover on the differential got torn loose at the bottom and the gear oil ran out and ruined the rear. It is OK for slow-speed use, and I purchased a replacement 20 years ago but have yet to install it. That also is on the list of future repairs.
The (replacement?) stack on your 1210 is much taller than the OEM stack on my 1920.Only one I've needed to replace was on the Ford 1210 (Shibaura) at nearly 40 years and mebbe 1400 hours. Went with a vertical for two reasons:
Original horizontal muffs were almost unobtainable, and the front discharge often made the exhaust head for me on the seat. Some pipe and a Cherry Bomb, a flapper and life is great! Pardon the fickle finger
