Hello, I am new here to the site. I have a Kubota BX with a 60” mid mount mower, was mowing and all of the sudden my mid pto lever started shaking and a loud noise coming from below. I turned off the mower and went back to the shop, removed the mower deck and the turned the shaft on the mower and it seemed fine, I then sat a large bag of fertilizer on the seat to activate the safety switch, turned on the mid pto and looked below. The shaft was not turning,I then tried the rear pto and it turns. Tractor drives in both 2 wheel drive and 4 wheel drive. I am thinking the shaft for the mid mount pto broke off? Has anyone replaced one, does the entire rear assembly need to be separated from the tractor or can this be done from the rear of the tractor. I am concerned this will become a very expensive repair, I am mechanically inclined and can work on things. Any help,input would be greatly appreciate.
Thank you,
Thank you,
