6,865
Thank you sir
We're pretty excited about new to us little mule :)
Sweet looking find you have there. Hope you can source a loader for it. Having run smallish tractors without loaders for many years, I’ve been near amazed how much a SSQA loader with bucket, forks, and grapple really puts the “Utility” in Compact Utility Tractor. Whatever it costs, it’s worth every penny.
fruitcakesa
M4 071
Oct 26, 2010
892
308
Cavendish Vermont
Finally started fluid service on the M with engine oil and filter. Actually started yesterday but after draining the crankcase I realized I only had about a gallon and a half in the shop and being Sunday I was SOL until today when the stores opened. Trans fluid and filters next. I have them in stock 😊
5,188
Yup.......on Sunday, Cavendish is likely a long way from any diesel rated oil.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
My son and I filled up 11 wildlife water tubs today. We need rain! Locally we are 10.2 inches from normal rain fall amount on the year. Were supposed to avg. Around 24in a year. During last summer, was the driest year out of 128 years of records. This summer wasn't much better, less than 3 inches of rain.
We got 3/10ths about a week ago, so there is a little bit of green.
Little bit of water in the tote went to a food plot.
Prayin for rain this week, I have planted seed in about 12 acres.
3,580
Changed engine oil & filter, air filter, fuel filter, topped off all 3 hydraulic reservoirs, tightened backhoe & subframe bolts, greased 56 zerks. Broke one zerk, but had a replacement on hand. Checked coolant & fan belt.
Tomorrow I will check tire pressures and tighten seat pivot.
trial and error
Feb 16, 2023
394
386
NY
Got do some more tests on the homemade pallet forks, I should be doing leaf stuff but I'm having too much fun "playing" with my new attachment, so much so that I decided to take down a decent size pine in the front just so I can use the forls for cleanup and see if it's significantly fast/easier then the previous way which was all hand loading. I had already taken the ballast off the back and put the "trailer mover" on so I didn't get to do any of the big chunks but yes this is significantly faster then the old way of doing it, I should only have one trailer load of bits and peices when I'm done, instead of the usual multiple loads to hand unload
Reactions: 10 users
L35
Jun 13, 2010
713
831
CT
Pulled a few small stumps today
Reactions: 19 users
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
I added my fancy step I made over the weekend.
I'm going to have my ex-motherinlaw check it for weight capacity/strength!!!! 20231106_105146.jpg
Reactions: 16 users
