5,164
Put air in the tires. One front was 13 psi and increased to 22. The other was still at 22 from the summer. Rear tires were 12 & 13 respectively, and I increased them to 20. Th inflation numbers were in very small print, and had to just about lay on my side to read them!
RMS
Sep 26, 2021
316
686
Buckfield Maine
Too bad Kubota cheaped out on doing this themselves. I did mine a couple weeks ago and think they will be beneficial with the front blower.
I put led's in my lx2610 and they didn't really help with the blower. Your front work lights are your friend using the blower.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,748
4,626
PEI Canada
well then, they will match the worklights😄
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
200
202
The instrument panel lamps on the B 2601 needs an LED upgrade.
Depending on the difficulty, I'm going to replace them with some LEDs.
There are 9 bulbs in there.
Old_Paint
Dec 5, 2020
2,056
2,356
AL
Must be a record breaking day for October 28th, 80* F here in southern Maine.
Opening day of deer season. The deer would spoil before dragging it out of the woods at this temperature.
So today I changed the oil & filter & fuel filter & greased her up.
Since putting a cab on the step loop seems a little tucked under the tractor when getting out. So took some aluminum angle and expanded steel and
made made a little extension so I'd have more to step on when existing.
It's gonna tuck more. The reason it's tucked is because it bent the stirrup and platform Doesn't have to bend much to nearly disappear under the platform. Here's what I did to mine:
I added a couple braces to keep the stirrup where I found it when I bought the tractor. I'm not what most would consider a heavy fella (180 lbs) but I noticed the platform twisting enough to distort the left fender when I climbed up using the stirrup. The bracecs go all the way to the frame at something of an angle which also keeps brush from dragging agains the stirrup and bending it back against the left rear tire, which as you can see is pretty close with the big feet on my LX. No more flex, and the stirrup's still in the same place it was when I took this photo nearly 2 years ago.
Reactions: 6 users
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,187
879
PNW-WA
I made a taller rear stand-off for the snow plow lines. The previous was shorter like the front.
Reactions: 6 users
5,164
I like your hooks for holding the hoses up so they won't get damaged. I don't recognize the type of setup that you have mounted on the front of the tractor. Is that something that you purchased or something that you designed and installed on your own? Either way it looks interesting and more pictures would be appreciated.
Trimley
Jul 25, 2023
1,187
879
PNW-WA
Thanks. I made the hooks, and made a mount to adapt a John Deere 54" 4-way blade. Check the Fabrication Forum for more.
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
Wow.
That's a great idea. I think I'll add a brace in the back and see if I can push it out a little. Thanks for posting that.
06B3030
Sep 21, 2015
170
233
MA
Not that I use it at night, but I decided to do the $20 upgrade to LED headlights.
YUP...LED upgrade is cheap and easy!!!!
5,188
I don't ride my bicycle at night,
I don't use my golf cart at night.
I don't use my tractor at night.
I just try to eat dinner, relax, and go to sleep at night!
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Worked on my road yesterday for about 5 hours. Putting the crown back on the road and smoothing it out. It probably needs a couple more hours of work then add a few more speed bumps back in to slow water run off(of coarse its gotta rain down here first, lol) from erosion. Then I plan on packing it back down with the weight of SVL75-2.
7,017
Water service in the "City" turned into a real mudhole. Found a break on the city side of the curb stop.
start:
found this....yuck.
new curbstop:
new line
backfill
Done
Reactions: 11 users
leveraddict
Apr 1, 2019
905
594
NEPA
Well said!
bird dogger
Feb 24, 2019
1,808
1,783
North Dakota
Now that Halloween is over with, it was time to start cleaning up the Haunted Halloween Trail displays. Fetching the autopsy table required the Kubota for some heavy lifting! Here's a couple pics from our Halloween trail that winds through the woods.
Rumor has it that on certain moonlit nights one can hear the seamstress still mending her husband's wardrobe!!
Reactions: 9 users
ajschnitzelbank
Aug 24, 2021
271
700
Rensselaer County NY
I’ve had my workshop in an 19 century (or perhaps 18th) outbuilding that’s falling apart, and my tools are starting to all get rusty. So I’m moving in to a newer shed. Tractor is making easy work of the heavy lifting! I thought I may have to take the folding outfeed table off, but the fully assembled table saw just squeezed through the door. In the new space it will be right behind a five foot wide door that’s under an overhang, which will be nice cutting bigger pieces.
Next up is an old three phase Jet drill press that I think is 750 pounds!
Reactions: 10 users
g_man
Feb 3, 2023
410
1,918
NE Vermont
Finished up the year end road side mowing. It suddenly got colder this week.
gg
Reactions: 7 users
pokey1416
Jun 24, 2020
572
885
SW Michigan
Waiting for the group to load up in trailer for Halloween. Nice and warm in cab, they all had to wear winter gear and got soaked. We got a little over 3” of the white stuff in 3 hours.
Reactions: 11 users
S-G-R
Jun 17, 2020
1,748
4,626
PEI Canada
Got the tractor back this afternoon from the dealer. Not a winter fan but im looking forward to putting this to work.
Reactions: 15 users
