L2501 Clutch and seat dummy plugs
Walker111
G5200
Sep 7, 2018
Fburg VA
Anyone know where I can get the female plug for the clutch and the male plug for the seat so I can jump them and bypass both without hacking up the wiring harness?
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Can’t help on the clutch switch, gear drive doesn’t have one, but the seat switch I just zip tied the lever of to the harness…
Easy enough to slide it back off if there is a time you may want it to be functional though
MOOTS
MX6000
Jun 27, 2019
2,165
2,689
Canton, Georgia
Depending what type of plug it is, I have a few made up at work “for testing purposes”. Male or female spade and a short piece of wire.
This is an F mower I had to pressure wash to find a hydraulic leak. Drove it around like this.
Walker111
G5200
Sep 7, 2018
Fburg VA
I have my seat switch zip tied and after seeing @Matt Ellerbee pic I made my own jumper. I was just looking for something cleaner. I think the clutch plug will be pretty easy to find. Seatbelt might be a little harder to find.
Walker111
G5200
Sep 7, 2018
Fburg VA
For the clutch, just run a wire from one to the other, a jumper... no need for another plug.
For the seat, the cable going to the seat switch, I looped it over the lever on the switch.... I might take photos of it next weekend...
yes, I made a jumper and have the seat switch zip tied. Just looking for a cleaner setup.
5,684
The WSM may have a page of connectors and cryptic part numbers. I know the BX23s does, found out who MADE the connectors that way.
Brazos
L2501DT
Jul 12, 2016
122
why would you want to kill this feature? It could save you life. Is there some reason you want to jump off your tractor while it is running in gear?
GrizBota
Apr 26, 2023
1,147
732
Oregon
Oddly enough, my B, which has a sticker on it that says not to start it while standing on the ground, has no safety to prevent exactly that from occurring. But my much older L (both HST) requires that the clutch (which the B doesn’t even have) to be pushed in to crank the starter. They both shut down if the PTO is running and you get out of the seat. Same thing if the treadle is depressed without a butt in the seat.
3,601
One might use it for troubleshooting.
I had a pocketful of "jumped connectors" when I was a mechanic. Saves tons of time.
I have no idea what the OP needs it for though.
Walker111
G5200
Sep 7, 2018
Fburg VA
you’ve never stood up to check clearance while moving? Or wanted to? That’s the biggest for me, but I have, plenty of times hit the pedal with my hand to get a little closer to whatever I was doing.
I understand why we have all this safety crap…because people sue company’s for their own stupidity. Luckily they looked out for the less stupid people and you only have to jump a wire to bypass it.
jaxs
B1750HST
Jun 22, 2023
926
705
That's true for some models but engineers are working feverishly to prevent it being so simple. As someone mentioned above, switches often work different depending on what position other switches are in. Zip tie takes care of complicated switches but some are designed to prevent zip tying. Ambulance chasing lawyers still win lawsuits even if plaintive disabled a switch that would have prevented his injury.
Dustball
2016 B2650HSDC
Sep 15, 2023
417
272
Hudson, WI
You'd have to look at your connector to see if there's any numbers on it. The seat switch connector on my B2560HSDC is a Deutsch DT04-2P on the seat side, DT06-2S on the tractor side.
Dustball
2016 B2650HSDC
Sep 15, 2023
417
272
Hudson, WI
If you can talk them into putting #s on seals and bearings the next round is on me. 🍻
They already do. I haven't had too much of an issue finding seals, bearings, and u-joints.
Just took pictures of a couple of examples-
Kubota 08101-06205
Mfg is KOYO 6205
Kubota 32430-25540
Mfg is NOK AE1375F
jaxs
B1750HST
Jun 22, 2023
926
705
Kubota 08101-06205
Mfg is KOYO 6205
Kubota 32430-25540
Mfg is NOK AE1375F
Those are aftermarket replacements and bearing says made in USA. I have never been able to find numbers on seals and bearings installed during manufacturing. I find that bearings from distributor outlets are usually less than half price and often 25% of those from dealers with vehicle/machine part numbers on package,not to mention close by same day availability. Only a few months ago I had to pay a machine shop to find replacement seals because the originals had no markings and was discontinued by Kubota.
SO I ask others. Are you able to cross reference then order bearings and seals for your Kubota from NAPA ,Rock Auto and bearing dealers?
Dustball
2016 B2650HSDC
Sep 15, 2023
417
272
Hudson, WI
It's a Japanese bearing. The sticker you see is applied over the original sticker.
Yes. I'm in the middle of rebuilding the entire front quick hitch/mid-PTO on my tractor and all of it has been aftermarket so far.
As for the 6205 bearing above, from Rock Auto-
6205 bearings are everywhere. It's an industry standard size.
jaxs
B1750HST
Jun 22, 2023
926
705
G-r-o=a-n , I've already recognized those aftermarket parts in picture have industrial #s printed on them. I'm saying industrial #s haven't been on oem parts I removed from tractors in the past. I'm not up for a pizzing contest,I just asked if the majority of people find industrial #s on oem bearings and seals installed at factory. Maybe I'm the only one to ignorant to see them or maybe you are the only one brilliant enough to see them. I've asked the general readership about it so time will tell.
Dustball
2016 B2650HSDC
Sep 15, 2023
417
272
Hudson, WI
Whatever. I guess I'll pretend I didn't see manufacturer markings on the parts I've replaced.
Yes, I agree there are many parts where there are no markings- mostly the custom manufactured parts. There are also many parts that have manufacturer markings. Bearings, seals, and u-joints are usually off-the-shelf parts that already exist.
