B7800 propeller shaft
Jacson
B7800
Oct 31, 2022
France
I have searched high and low but unable to find any sevice information on the b7800 hst propeller shaft, apart from the tractor needs to be split to remove it.
Mine has quite a bit of play in the coupling on the front on the shaft behind the clutch housing. Is this normal or how much is too much, don't want to split the tractor unnecessarily but also don't want to make things worse, any advise welcome. Thanks.
jaxs
B1750HST
Jun 22, 2023
924
704
Those are cv joints so quite a bit is subjective but if one has remarkably more than other I'd think it is worn out.
jmurray
B7800HST
Nov 29, 2023
Curious if you have been able to remove shaft yet without splitting tractor?...I have the exact same issue.
3,185
1,604
There are a few models of the B series that you can remove the shaft without separating the tractor.
It is very simple to tell, drive the 2 roll pins out of the splined couplers and see if the couplers will slide one way or the other enough to release the shaft. The shaft will either drop out or it won't.
Jacson
B7800
Oct 31, 2022
France
No i still have the problem, I am just taking things easy untill I can manage without the tractor. Still not sure if some play is normal I have watched several videos of B7800 and hear the same chatter noise from the shaft when the tractor is stopped. Another member said it is possible to remove the shaft on some B models so I will take another look, but think splitting is going to have to be done to remedy the problem.
Jacson
B7800
Oct 31, 2022
France
Thanks for the info I will take another look.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
On my b2400 I cut a hole in the floor pan with a hole saw to allow access to the upper pin slide coupler.
Maybe for you?????
drewzee87t
L45 TLB, B2910 Turbo
May 20, 2016
176
misery
It comes out with sleeves and pins as described by whitetiger. Attached screenshot from WSM for your brother b2910
8,743
This is the shaft they are talking about.
You are pointing to a completely different shaft that runs the Front axle on a completely different tractor. ;)
drewzee87t
May 20, 2016
176
misery
You are pointing to a completely different shaft that runs the Front axle on a completely different tractor. View attachment 117242 ;)
Glad I could help LOL. The B7800 and the B2910 are mechanically the same machine with all the same part numbers.
One could simply point out my misunderstanding without being a douche, but whatever. People stop posting and sites go dead.
Kindest Regards
8,743
Kindest Regards
You calling the Moderator of a forum a "douche" for pointing out that your pointing to pictures of the FWD propeller shaft which wasn't the shaft in question is not being a "douche" it's the Moderator keeping misinformation from confusing the OP.
And I'm 1000% sure that the site will carry on quite fine with me doing what I'm doing!
Have a great day!
3,215
While the Wolfman was in error I believe, as the B7800 is supposed to be essentially identical to my B2910 mechanically, and actually the B7800 is covered as an appendix to my B2910 WSM.
But I see nothing offensive in the Wolfman's post where he pointed out you were referring to a different shaft. Not sure what you actually replied as I see your post was edited by a moderator.
8,743
The only thing I edited with his post, was that he had replied inside the quotes, and I moved it outside the quotes.
drewzee87t
May 20, 2016
176
misery
We could all stand to be a little more pleasant is all. I won't post any more disinformation (MOD EDIT: misinformation) and I will leave it to the experts to be the source of misinformation (MOD EDIT: Information). I probably should have been banned for this, so that's a plus. Hopefully the OP will get the help needed.
Thanks
