Flat Rear Tire
Fastball714
L4060HSTC, B3300SU
Feb 27, 2021
52
56
Georgia
I have a deer antler in my rear water filled tire. Do they make a plug that can seal a 1/2" to 3/4" hole. Tire is tubeless. It's a 17.5 X 24, if that matters.
5,589
IN the tread or in the side wall ? If it is in the tread they might be able to do a patch from the inside, and a tube,, if its inthe side wall I doubt if there is much you can do
Elliott in GA
Mar 10, 2021
881
891
North Georgia
If it cannot be patched and it is too new to throw away, you could probably have both your rear tires filled with foam. It is not as heavy as liquid ballast, but you will never have another flat. There are pros and cons to foam filled tires.
GrumpyFarmer
5,207
Good day. Have you ever used a tire repair kit with the long rubber threads / glue and the t handle tool that threads the rubbers threads into the hole? (You keep adding threads until it’s full, they work well but they do have a limit). I’ve not used on a tractor but I have on a motorcyle (yes I know you are not supposed to do that on an MC tire, sometimes not much choice) and auto. Depending on how bad your puncture is, I’d probably try that, and if still worried, drain water, break the bead and put a sealant of some sorts on the inside and outside…flex seal seams to do wonders under water so id try some of there goop. (I’ve used under water on a pool liner and a tote and both have held for years). Tractors not a high speed application so maybe it’s worth a try before a new tire. But I’ve not tried it so I don’t know. At you own risk of course. If worried pay the piper. Maybe call a tire repair service for farmers see what they recommend or as mentioned by Mr Elliot, get em foamed. Lots of options better than paying the piper for a new tire.
Fastball714
L4060HSTC, B3300SU
Feb 27, 2021
52
56
Georgia
It's in the tread area. It's a R4 tire. Only 500 hours on tractor. I will check into the patch or maybe foam filled. I never thought a deer could cause damage to my tractor.
If the patch works, how can you add antifreeze to the tire?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,174
1,162
E.
Deeres can do a lot of damage to cars so not surprised they could damage a Kubota (haha)
Myself I would vulcanize patch from inside and tube it.
GrizBota
Apr 26, 2023
1,147
733
Oregon
Yup, a tube with a boot inside the tire over the hole. Glue the boot to the tire.
3,396
Actually foam is about the heaviest fill you can get from what I understand. One reason is it fills the tire 100 percent, as compared to 70 percent for liquid fill.
Of course I am referring to the foam such as installed in construction equipment tires. I have four foam filled tires on my BX and two on the front of the B2910.
I am not sure how foam compares to beat juice on a per unit volume basis. But liquid ballast would have to be almost 50 percent heavier than foam just for the filled tires to have equal weight.
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
107
sheridan
Don't know for sure but I figure foam filled tires would about as cushy as the rear tires on my old Allis Chalmers here.
Elliott in GA
Mar 10, 2021
881
891
North Georgia
Well, I called the place listed in my initial post. They have have two types of foam - Super Light and Heavy. They mostly fill tractor tires with Super Light. The Super light yields a filled weight approximately the same as water (less than Beet Juice), and it is a spongy fill (not nearly as rigid as foam used to be).
Finally, the approximate costs to fill my LX2610 SU tires (Front 25x8.5-14 / Rear 15-19.5) would be $500 per front tire and $1,200 per rear tire. You have to bring/ship the mounted tires to them (just west of Atlanta), and the process takes two days (fill and cure).
My rear tires are filled with Windshield washer fluid (part of the prep included in the tractor's price (which was under MSRP). Do I plan to have my tires foamed - no. However, I could change my mind if I started having flats. After I tore down a dilapidated hog parlor, I moved all of the lumber and tin roofing (both full of nails) to two dumpsters (could not get them closer) about 200 yards away with my grapple. I backed the entire way to the dumpsters, and I had my wife looking for anything that fell off along the way. I was very relieved that I did not get a puncture. If I were doing that kind of work even once every couple of years, I would get the foam.
GrizBota
Apr 26, 2023
1,147
733
Oregon
@Elliott in GA You got lucky. It cost me a pretty penny to have the mobile service fix the nail hole in my L’s R1 rear tire. And I don’t think there were that many nails. Just grading for new residential construction, after a deck was built.
Seems like anytime I have a residential carpenter on a site, I’ll get a mail in something. It’s almost like they think they get paid by the pound for nails.
3,396
My tires are filled with Windshield washer fluid (part of the prep included in the tractor's price (which was under MSRP). Do I plan to have my tires foamed - no. However, I could change my mind if I started having flats. After I tore down a dilapidated hog parlor, I moved all of the lumber and tin roofing (both full of nails) to two dumpsters (could not get them closer) about 200 yards away with my grapple. I backed the entire way to the dumpsters, and I had my wife looking for anything that fell off along the way. I was very relieved that I did not get a puncture. If I were doing that kind of work even once every couple of years, I would get the foam.
The rear tires on my B 2910 are filled with windshield washer fluid and have been for 20 years now. Never a puncture and I hope I don’t have to make a decision if I do get one. Actually, if I did get one I would probably just get it repaired and cross my fingers for another 20 years, which would put me close to 97 years old!
So I guess we’re in the same place. For the front tires on my B2910 or the little tires on the BX the cost was much less and well worth it. Prices may vary by location. I think for my son-in-law‘s BX23S a couple years ago it cost about $350 to have all four tires filled with foam. This is the industrial stuff which is heavy.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
I’ve called and spoke with north Georgia flatproofing about doing our ventrac tires at work. Was quoted $195 per tire, there are 8 of them on the machine. Each one would add 34lbs. Sent my findings to the higher ups and was shot down. 300 hrs on the machine and each tire has 7-10 plugs in them.
Elliott in GA
Mar 10, 2021
881
891
North Georgia
It is definitely something that is worth it in some uses, and it sounds like you have such a need.
I wonder if your bosses have considered how much downtime all those plugs cause - and the associated costs, including lost manhours.
NorthwoodsLife
Oct 15, 2021
1,410
1,475
Wisconsin
Holy Smokes! I'm in the wrong business! How many new tires can you buy for that kind of money!
Frankly, I'm shocked that a deer antler went thru your tire.
Fastball714
L4060HSTC, B3300SU
Feb 27, 2021
52
56
Georgia
We foamed filled all our forklift tires at work. It was well worth the investment. I don't think it would payoff on my tractor.
I found a place that will patch the hole and will put a tube in, if it fails. Thanks for all the suggestions.
