QH16
kcs
Kubota B2650
Jan 9, 2021
148
I have one of these on my B2650 one side hooks fine. The other seems too wide is this the right QH for my tractor?
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Here are some pictures
Can you flip the brackets on the implement? It looks like you could gain (or narrow) width by doing so. I think you could add washers (both sides) between bracket and implement to get the width you need.
6,014
I looked at the pix again, the 'arms' are offset welded, but bolted onto the 'implement' , so maybe you can flip them over to gain some distance ??
OK, it's orange, but WHAT is it ???
GrumpyFarmer
4,671
It’s hard to say from the pics, but I wonder if your link arms are same length and is the implement square to the QH with arms centered and same length? Is there any sway to the link arms?…could it be canted/off center?
Trimley
Jul 25, 2023
1,181
872
PNW-WA
You more/less said the same thing I did above you! 🤡🤪
6,014
somehow.. your post #5 'magically' showed up AFTER I'd posted #6, but not instantly...sigh
admittedly I'm a dinosaur, I expect 5 to come BEFORE 6.....
must be this 'new math ' being applied to computerz...
kcs
Kubota B2650
Jan 9, 2021
148
Wow thanks for all the answers. I will try flipping the arms tomorrow. It is a finish mower. 60”. Not sure if the model. The upper hook hooks to the flexible link right. Looks like the stable link is too big for the hook on the QH Sorry I’m new with the tractor stuff and QH
Elliott in GA
Mar 10, 2021
843
848
North Georgia
As mentioned twice above, you probably need to flip the arms and maybe move them to the inside of the mounting plate.
I had to adjust/remount mine on my LP Finish mower to fit my QH10.
Elliott in GA
Mar 10, 2021
843
848
North Georgia
If it is like mine, the QH hook does not hook to anything. The plates that came with my QH attach to the Y yolk at the top of the mower A frame. This mounting system allows for maximum mower float.
kcs
Kubota B2650
Jan 9, 2021
148
Awesome. Thanks. I got the finish mower when I got the tractor and got the QH a few weeks ago. Old man and bad back needed some help. I will try reversing them tomorrow. OTT is the greatest.
Mak65
L2501 HST
Apr 25, 2019
136
112
TX
Not sure which finish mower you have but the FDR16 has this in its feature document…
Lower hitch points adjust in and out
Accommodates many tractor configurations by adjusting in and out. So, as everyone said switch them.
