At this point in my life, especially post-covid prices, I'll be money ahead in no time.Bought the 185 Miller and spool gun in @ 1986 - seemed like overkill at the time but it is one purchase I have never regretted. Just did up some brackets on a deck rail reno. Worked great - now if I could only make my welds look like some of the members here (you know who you are...)
Congratulations.Right on. I have a few friends who use the 211 in the commercial application. They both rated them highly suggested. New, I could not justify when I was looking, no matter. This one popped up while scrolling the local marketplace. He listed it at $1800. I got it for $1300. It pays to be polite and not like a lowballer where they get insulted, which has happened to me on several things I've wanted to buy. I got lucky.
Those I know who have used this machine on a daily (commercial) basis, said they're real nice machines, and they have no problem on 1/2" material.I'm on my second 211, I had an earlier model I bought about 15 years ago, I think, and when the new smaller version came out, I sold the older one to a friend and bought the newer model like you have.
Great machine, I use mine a lot. I have the spool gun, but haven't tried welding aluminum yet.
Duty cycle becomes a much bigger issue for commercial application where downtime isn't acceptable. No commercial shop is going to buy a 211 to weld 1/2" plate all day long. A body shop or light fabrication (sheet metal) shop might. Not trying to rain on your parade but when choosing a welder for commercial use where material thickness is commonly 3/8" or greater you're going to be paying a lot more than $2k.Those I know who have used this machine on a daily (commercial) basis, said they're real nice machines, and they have no problem on 1/2" material.
That info says a lot, coming from someone in their skillset. That (and the name on the box) kept my focus on finding one.
Or maybe?I was expecting....
Your situation is similar to mine. I don't like having to rely on others for help, or pay someone for something I can do. That worked for most of my existence so far. Which is what led me to buy my 23s.Congratulations.
That was a once in a lifetime deal on a GREAT welder.
They are such a handy size and mine has been absolutely trouble free for the 10 years I've used it.
Spool Gun:
I rarely have a need to weld anything aluminum....and frankly, it takes some practice to learn to use a Spool Gun and weld aluminum. But because I live on my property (25 miles from the nearest small town) I wanted to be able to make small repairs or cobble together aluminum items when needed.
In past year....I've used the spool gun exactly once, and that was to make a small repair on my Brother's boat trailer. But I HAVE used it enough in the past to easily have saved enough to pay for it.
I keep a small bottle of straight Argon gas for running the spool gun and aluminum.
Anyway, enjoy your new welder. It will last you a lifetime.
Duty cycle is key to being productive. I never implied nor mentioned they were welding 1/2" continuous, but for how they were using it out on the floor, it was convenient, small, and could do small things so the larger machines didn't have to be dragged over to do what the 211 could.Duty cycle becomes a much bigger issue for commercial application where downtime isn't acceptable. No commercial shop is going to buy a 211 to weld 1/2" plate all day long. A body shop or light fabrication (sheet metal) shop might. Not trying to rain on your parade but when choosing a welder for commercial use where material thickness is commonly 3/8" or greater you're going to be paying a lot more than $2k.
You got a great deal on a what is basically a very nice hobbyist welding machine.
Congrats. About 15 or so years ago I bought a MM175 and have used it for making a bunch of things. If I were starting out now, the MM211 looks like a more desirable machine. I would appreciate the 120/240 capability, the ability to use a spool gun, and (I assume) a better duty cycle. I think the newer ones are inverter, so they'd be lighter to lug into places the cart wouldn't roll into.Bought from an older gentleman. He said there was about an hour on it. I've wanted this welder now for quite a while.
A Millermatic 211.
It come with the cart, small tank, wire, hood, gloves and literature. $1300 View attachment 114056
The 211 being 220v was a selling point for me. 110v works OK. My previous Hobart Handler 120 was a fussy machine, and frustrating to use. This one (hopefully) should keep my blood pressure in check.Congrats. About 15 or so years ago I bought a MM175 and have used it for making a bunch of things. If I were starting out now, the MM211 looks like a more desirable machine. I would appreciate the 120/240 capability, the ability to use a spool gun, and (I assume) a better duty cycle. I think the newer ones are inverter, so they'd be lighter to lug into places the cart wouldn't roll into.
I'm aware that 120/240V stuff isn't as capable at 120V. My Everlast stick welder and Hypertherm Powermax30 AIR are dual voltage with different capabilities. The real appeal of the Hypertherm was that it's self-contained, can operate on 120V, and is capable of cutting any thickness I generally need to.The 211 being 220v was a selling point for me. 110v works OK. My previous Hobart Handler 120 was a fussy machine, and frustrating to use. This one (hopefully) should keep my blood pressure in check.
I wired for 220v years ago when I was running a Lincoln stick. I need to change out (I think) one receptacle to be up and running.I'm aware that 120/240V stuff isn't as capable at 120V. My Everlast stick welder and Hypertherm Powermax30 AIR are dual voltage with different capabilities. The real appeal of the Hypertherm was that it's self-contained, can operate on 120V, and is capable of cutting any thickness I generally need to.
I've had a Hypertherm Powermax 380 for 20 years or so and it struggles on 1/2" plate which isn't surprising given that the 380 in the name means that it's rated for 3/8" plate. I run both welders and the plasma on 220V and always have. Heck, I installed a hot tub seven or eight years ago and wired it up for 220V too. Welders and hot tubs are much more efficient running on 220V.I wired for 220v years ago when I was running a Lincoln stick. I need to change out (I think) one receptacle to be up and running.
The Hypertherm sounds appealing for sure.
I agree sir.Duty cycle becomes a much bigger issue for commercial application where downtime isn't acceptable. No commercial shop is going to buy a 211 to weld 1/2" plate all day long. A body shop or light fabrication (sheet metal) shop might. Not trying to rain on your parade but when choosing a welder for commercial use where material thickness is commonly 3/8" or greater you're going to be paying a lot more than $2k.
Hard to tell.............Or maybe?
I really thought this thread was going to have a mig (or spot/resistance) welder on the end of the backhoeā¦itās still a good read but I am disappointed this thread did not invoke the BH.Hard to tell.............
Your, Pic is less than ideal.
but maybe Evil Twins pic is a "butter face" in person.
Tough call, but I ain't no prize neither, so theres that too....................I'd probably "date" any of them.......hahahahahh
