This is a 2015 BX5450 Snowblower Package, consisting of the snowblower, BX2751 hydraulic actuator (for lift and lowering), PTO shaft (44 & 3/8" L) and manual discharge chute actuator rod and pedestal. I am the original owner. Located in Michigan, this accessory has seen extremely low usage of approximately 7 hours of operation. Winters in our immediate location have proven to not justify possession. The unit has been stored in an insulated, temp controlled garage its entire existance. It is of exceptional condition....without exception, all bearings have been meticulously maintained, silk-smooth in motion. Zero rust anywhere. Drive chain and sprockets in perfect condition, exhibiting no wear. Auger halves are free on shafts, no bends in helix paddles. Superficial stone chips exist on augers, intentionally left visible when painted with thin single coat of Kubota Bright Orange II paint.
Cutter edge along bottom of snowbox reveals crisp edge over the entire length. Skids mounted on ends of snow box have been widened and lengthened. There are no downsides to the condition of the machine.
I do not offer shipping but may assist with the process if carefully planned. Will consider delivery to approximately 250 miles for paid fuel expense. Two independent Kubota dealers have indicated this package will be suitable for any BX-series sub-compact tractor. It is the purchasers responsibility to confirm that and decide accordingly. Price is $2,450 for the entire package as described.
