it is fullOk, I'll ask the stupid question. Does it have hydraulic fluid in it?
loosened the filter . started tractor and had a very small stream of hyd fluid coming out about the diameter of pencil leadI've seen this exact scenario a couple of times.
You first need to establish if the pump is spinning and moving fluid.
Loosen both filters and crank the engine and check for any flow.
That does not look good. You will get a much more reliable indication of what the pump is doing with the procedure I suggested. You can rev the engine hard and let it run for an extended period of time. What you are seeing may be just drain back.loosened the filter . started tractor and had a very small stream of hyd fluid coming out about the diameter of pencil lead
thanks Dan you have been very helpfulThat does not look good. You will get a much more reliable indication of what the pump is doing with the procedure I suggested. You can rev the engine hard and let it run for an extended period of time. What you are seeing may be just drain back.
loosened filter . ran full throttle for a while . no change on the stream.thanks Dan you have been very helpful
looks like the pump died to meloosened filter . ran full throttle for a while . no change on the stream.
You need to verify there is oil delivery to the pump before you condemn it. Have you tried manually priming it?looks like the pump died to me
