Utility bucket
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
Got another leak. 80 year old black iron pipe crosses under the driveway in a half mile line. Of course happens in the worst time.
Studying bucket designs especially for working around utilities. Unbolted the teeth from the 12” B26 bucket. Has a flat cutting bar. Hope less chance of hooking the line when uncovering and causing collateral damage. Their are some specialty buckets made just for this type work. This part of driveway is part of the 300 year old wagon road that used rocks and clay to fill ruts. Tree lined in the woods so there is going to be roots.
Plan is to uncover both the line on sides. Cut. Ditch and remove the old line. Thread the two ends. SS couplings. PVC pipe inside 4” corrugated plastic drain pipe. Couple of bags of sackcrete, left in the bag, on the pipe on the ditch side.
Several repairs over decades on this line. Some point will need to replace.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
561
325
Mandeville Louisiana
What size is the black iron pipe, I assume it's for potable water. Is the driveway concrete. Consider rolls of poly pipe, use a trencher and trench parallel to the old, connect ends and abandon toe old pipe in place. Pipe is getting any cheaper! When replacing consider pressure drop. Another thought is to drill a new well closer to your needs.
Smokeydog
Jun 2, 2020
757
729
3/4”. Can’t change position of spring. 1/2 mile and 275’ elevation change of main line.
A trencher is more efficient than backhoe for long runs. Not too good for repairs.
4,060
10,622
I personally wouldn't use PVC for the repair, poly would be a much better choice as it's flexible.
And threading the old iron pipe in the ground, wow you are a determined person.
Threading old pipe on a bench is a chore but in a trench it's a really work out.
They do have thread less repair fittings for instances just like this.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
I really like PEX, but poly will hold up much better with rock, as it has a much thicker wall.
I can't stand Poly. I've had to dig up my main water line three times due to leaks. 3ft down, all by hand. Now since I have the BX23s, it probably won't happen again. 🤫
10,622
If you don't use compression fittings then it will leak at the fittings.
The old style barb fittings suck.
7,503
It's excellent for repairs if you have a back hoe on the other end. ;)
Trimley
Jul 25, 2023
1,181
872
PNW-WA
I found that out once. The other two leaks were in the run. Likely rocks. If I have to dig it up again, I'll deal with it.
Don't Jinx me dangit...lol.
trial and error
Feb 16, 2023
394
386
NY
Barb fittings work fine for poly pipe schedule 40 are the best brass ones, don't like to come back apart. The trick is to allow the pipe to cool before tightening clamps so they don't "sink" into the pipe. Also double clamp in opposing directions. I deal with it every day. maybe underground is different but I don't get leaks replacing pressure tanks using the above method
Smokeydog
Jun 2, 2020
757
729
kinda curious as to why you haven't replaced 100% of that 80 year old black iron pipe after so many 'patches' ?
It’s getting close to being replaced. With trees growing, roads there is always maintenance. Been doing it for 50 years. That’s only half of buried lines. Tough terrain to dig. Do have options. New 1” pvc line laid where 1/2mile underground electricity was run that I could possibly use or tie in to utility water.
