Is there a rake attachment?
Bearcatrp
Mar 28, 2023
1,331
973
Minnesota
Need a rake attachment on the 3 point that won’t dig into the ground. About 1 to 2 inches above the hard ground. Been reading on a bagger system for my 1880 but read they are junk. Is there a rake attachment? Thanks.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,108
1,105
E.
there are almost limitless makers of landscape rakes out there. Addition of a wheel kit or skid shoe kit and it will stay above digging in like you want.
Bearcatrp
Mar 28, 2023
1,331
973
Minnesota
Have you thought about using a blower instead of a rake??
Too large my large yard. My last garden tractor had a 3 bag catcher which worked fairly well. Should have kept it for this but sold it.
Bearcatrp
Mar 28, 2023
1,331
973
Minnesota
I found this but no way I’ll pay $1500 for it. But this looks like it will work.
6,313
If you’re looking for a leaf rake/pine straw rake like this, they’re quite a bit lighter duty than a landscape rake. Won’t get every leaf, so if you’re looking for HOA Yard of The Month perfection, this ain’t it. If you want to remove the vast majority such that mulching the leftovers is realistic, might be an option.
Mine is from Titan Attachments and is admittedly the cheapest piece of Chineseum we have. I use it maybe 4 hours a year, but when I need it, I need it. So I kind of figure if it lasts 100 hours, that’s 25 years. 🤷‍♂️
jaxs
B1750HST
Jun 22, 2023
1,046
794
Someone sells something for anything you can imagine if you have money to spend.
Nicfin36
Jun 19, 2019
1,018
472
Decatur, AL
I have a landscape rake and recently tried to use it to rake up cut grass in my field before tilling. It did a very poor job on raking up the grass. Like Fordtech suggested, I felt like a pine needle rake would have done a better job, but don't know for sure. I just wouldn't recommend a landscape rake for cut grass.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Get a towable sweeper if trying to get grass clipping and chopped leaves
edit: we use one similar to this for collecting grass and leaves for compost
Use zero turn to mow but pull this with garden tractor. Added a cheap atv winch for power dump 😂 (my kids usually pull it and they couldn’t dump it when full of grass) I do need to reinforce the top bar on it though where the winch cable is hooked
Bearcatrp
Mar 28, 2023
1,331
973
Minnesota
I like that. $429 from Titan. May go with this. Don’t need perfection but clear up most. Thanks for the tip.
