Pickup truck loader (AKA boom pole)
2,839
Remember as you move away from the pivot point the AMOUNT you can lift will decrease proportionally.
If that hole is through the pipe - that will be the first place it will bend or break once the load gets heavy.
Sharon Bayes
Kabota b1700 HST
Oct 2, 2023
Somerville Ohio
Thank you. It's already been tested at 300 pounds and that is our target weight
3,101
How about an action shot? (in use)
3,285
1,902
Welcome aboard.
I have to admit, when I saw the title I thought someone had installed a front end loader on a pickup truck.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
It picked up our belly mower so we could take it to our barn. Worked good but then it started to rotate. Dangerous, will have to find a solution.
Rope on each end of the deck, tied to the relative side of the tractor.
Be careful
I'd advise no one standing near. No offense, thats a risky contraption.
NorthwoodsLife
Oct 15, 2021
1,317
1,321
Wisconsin
Nice build. Genius maybe.
I use the loader, forks, and some chain. And a big long ballast.
Showmedata
LX3310
May 18, 2022
202
169
Boulder CO
Welcome aboard.
Well... a friend has one of these:
I guess it doesn't qualify because the truck bed is replaced with an excavator?
And a friend of a friend brought his forklift-and-boom-crane variant to help fetch my lathe out of first friend's truck:
NorthwoodsLife
Oct 15, 2021
1,317
1,321
Wisconsin
GrizBota
Apr 26, 2023
1,147
732
Oregon
Yup, needs triangulation. Rigid triangles are your friend. See @mcfarmall post of the old time 3 point boom. I’ve got one, but not that pretty (it matches my 8N). Now that I have a modern FEL and pallet forks, the old boom will probably quietly rust away.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
PF's are AWESOME!!!
I'm sure I could rig this differently to put it in a pickup bed if I had to. As it was I was just transporting it from pt. A to pt. B
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Mower deck transport is sketchy. They swing every which way. For PFs, four short ropes looped each end. One on each deck wheel, four loops to the forks is how I'd do it. Keep the deck as close to the forks as possible to eliminate swing.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Or, spread the forks and pick up the mower like a pallet. Put a ratchet strap on it too if things are going to be less than smooth.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
Griz
Why didn't I think of that?
Excellent idea.
(actually, for this particular "move" I was leaning the deck up against my shed and didn't have confidence in my PF SKILLS" that day, just after I got my forks.....so left very little to chance.
8,848
You need a triangle for the mount, not two independent arms.
Like others have said copy the above boom pole design.
