2005 Kubota L4300DT with only 200hrs on it.
Figured I’d ask you folks here and maybe one of y’all have had a similar issue
Tractor was running and starting perfectly without any issues. Did a lot of brush hogging on some pasture and wooded areas and had no issues. Came out the next day to start and it would fire up and die immediately. Did this several times and I finally realized if I kicked it back to the pre heat glow plugs, it would run for a few seconds and I kept doing it repeatedly quickly (yes I know it’s not good but gotta run the tractor) and it would finally stay running. Takes me 2-3 times of doing this before I can kick it over to run and it stays running usually. Once running it has zero issues. I have a video of me doing this but I guess we can’t post videos on here.
Also I’m in south Texas so it ain’t cold so I don’t think it would be the glow plugs and don’t have any fuel leaks that I can find and I checked all fluids, cleaned all electrical connections including the key switch, and cleaned the air filter. So I’m a little baffled and any help would appreciated and yes I’m very mechanically inclined just not electrically inclined
