g_man
Feb 3, 2023
390
1,826
NE Vermont
Last week I started turning a 4-wheeler trail into a tractor road so I can cut some softwood this winter. This section is done and cleaned up pretty well.
I widen the next stretch by hand
Then roughed it into a tractor road with my small TD7 dozer.
Then I used the tractor to widen the next stretch which is what I did today
gg
Reactions: 10 users
ctfjr
L3800HST
Dec 7, 2009
1,982
2,540
central ct
Used the box blade to move and spread 10yds of topsoil. I thought it did a respectable job over an area about 30' wide X 150' long. Then came the manual labor. Used a spreader for 100lbs of limestone followed by my own mixture of seed (tall fescue + contractor's northern mix).
Got to rake out about 1/3 of it before 'date night din din'. Finish tomorrow.
Trustable
l2501HST
Jul 5, 2022
397
411
The reason primers are colored is so the inspector knows if it's been applied! If your job is being inspected and no primer is seen in the joints you will get to start over!
Interesting. I never realized they were colored for a reason besides just to look different than the glue.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Wash time, candle ran out, I will haave to finish in the morning.
Another 4+ hours of washing today and she's almost clean. This damn machine traps grease everywhere. I had grease balls the size of golf balls coming out of from the elbow skid plates. I'm glad I ordered the shell brand grease that it comes from the factory, cause that's what I'm switching back to, it's a like a soap based grease. More on that later.
SteveBX23
LX2610SU; BH77
May 23, 2021
185
313
South Jersey
Nice looking seeder. Could you use it on an existing lawn or would it rip the yard up?
You can use it on an existing grass stand, with varying results. It depends on how well the root structure is with what’s there. Some places it does a great job with overseeding without much disturbance, and some spots it can tear it up where it’s not well rooted. But the results end up being pretty good either way.
SteveBX23
LX2610SU; BH77
May 23, 2021
185
313
South Jersey
Does that put it down in rows, or random?
Rows. In the picture with the dirt, it’s kind of showing the finish touch from the cultipacker that’s on the rear of the seeder. It has a PTO driven slicer in the front of it that cuts into the ground to create the seed bedding. 50% overlap or multiple directions ends up being a good application
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,563
Nice! I used a cheap one and it was like I was planting corn. Lol.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
Got some new shoes…
Got to meet a very kind fellow OTT member and we traded the R4s-R1s.
Reactions: 13 users
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,726
4,545
PEI Canada
Not the tool I should of used but it was the only tool that I had to use. LX3310 and FDR2584. The clover/weeds were between 12-36" with the odd 48" straggler.
I set the wheels to the highest position and had to go quite slow but for what I had to work with it turned out reasonably decent.
Reactions: 12 users
K7G
L2501HST, LA526 w/ L2248, BB1260, RCR1860, EA Disc Harrow
May 29, 2023
76
112
Aladamnbama
Added some bolt-on hooks from Ken. Pretty easy job. Also purchased fluids and filters for the 50 hour service that’s coming up in 10 hours. Added a vent and fan/louvers to the shop where the tractor is stored and installed a timer to keep the air reasonably refreshed. The shop has already lost that musty smell. Getting prepared to plant pollinators just outside of the lawn and then, disc the property edge to encourage forbs.
pokey1416
Jun 24, 2020
572
885
SW Michigan
IMG_2023-09-23-173557.jpeg Dropped the BH and as I started to put 3PH on I thought I’d drill out the drawbar so a 1” Clevis will fit. I think Kubota needs to step up and do this at the factory. Tried a 1” bit in pops ole’ trusty drill press - man is that some hard steel. Switched to a step drill which would have been 1-1/8”. No luck there either. Drank a couple liquid brain improvers, smoked the bit and squealed the press. Gave up gonna take it to fab guy.
Still a positive as I didn’t start a fire.
Reactions: 8 users
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Yanked down "downed trees" from Hurricane Lee back to the 22 snow.jpg brush pile. No pics from today
so I'll just insert a cpuple random pix from my Kubota stash of pix from last winter
.....I know we all like pix, right? !
dlsmith
BX2230, LA211
Nov 15, 2018
1,362
1,063
Goshen, IN
I ran into the same thing this week, but on the clutch Z-bar for my Nova. I'm changing the linkage to Heim joints from bent rods and cotter pins. I drilled the clutch pedal arm out no problem, but the Z-bar was harder than Kelsey's nuts. A 3/8" cobalt bit wouldn't do much more than knock off the paint, and running a file over it was confirmation it was hardened. I ended up using a 5/16" bolt with a spacer sleeve in the Heim end. I imagine if I heated it up red hot, that may have taken the temper out of it, but decided not to.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
351
665
NH/VT NEK
As I posted a few weeks back we had a large solar install go in that required a bunch of driveway destruction and rebuild. After the initial re-fill of the ditch, and a few settling/regrade sessions, I had 15yd or ~20tons of recycled asphalt dropped the other day and spent a few hours yesterday spreading and grading with the bucket and box blade. Came out well. Should set up well for winter and then if I need to I can get some more RAP in the Spring and top dress.
IMG_5205.jpeg IMG_5070.jpeg IMG_5073.jpeg IMG_5079.jpeg IMG_5082.jpeg IMG_5200.jpeg IMG_5201.jpeg IMG_5205.jpeg IMG_5210.jpeg IMG_5211.jpeg IMG_5212.jpeg
Reactions: 10 users
