Pallet Fork Platform
6,279
The big difference in 'tractor with loader vs forklift' is when a hose breaks...
On a tractor you'll come down REAL FAST, on a forklift it's a sloooow descent.
At least that's how my forklift was setup, some kind of 'flow restrictor' going down,same as dump trailers.
Ideally, you rent a manlift for the one job, or buy one if you need it a lot
MountainMeadows
Jun 6, 2022
220
291
Poconos, PA
My cheap a$$ would have a very difficult time paying $100+ for those, when a 1/4" drill bit and two "18"ish" pieces of C channel would do the exact same thing.
Just sayin ;)
Yeah, I could make one myself no problem other then the time it would take. I'd rather spend 1/3 the time at my business earning the funds to purchase one.
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
Made my man basket. Study enough to hold tools and chainsaw. Even use it for sawhorses. Wife is a good operator when trimming trees. Made adjustable safety poles to support the basket it case of hydraulic failure. IMG_1943.jpeg IMG_1951.jpeg IMG_1952.jpeg IMG_1953.jpeg IMG_0390.jpeg
Reactions: 13 users
06B3030
Sep 21, 2015
170
233
MA
5,269
6,968
simple...
ferguson
L3130
Jan 19, 2022
331
136
w.v.
Gut one of thos 300 gal toats the top was cut out . the company that was selling them $50. for un cut talked the guy down $10 after he put it in my truck said O gust take it. Works great have trimed sum branckes but realy got it for picking fruit from my trees.
MountainMeadows
Jun 6, 2022
220
291
Poconos, PA
Jasonized
L3902, LA526, box scraper, grapple, pallet forks, tree ripper, lane shark 3
May 16, 2023
162
California coast
I actually have that same model…. I have used it once. It more or less works, if you treat it as what it is, and not what you WANT it to be. It worked for what I bought it for.
that said, it works better than nothing. I actually roped it to the fork back shield, so it couldn’t slide. That helped a bit.
the biggest issue I ran into was that you can’t raise or lower it in use. Since as you raise the fel, it rotates, making the platform angle. So I still had to use a ladder to get into it!
Anyway, yeah, I wouldn’t buy it again.
Trapper Bob
L4701, Wicked grapple, 7’ box blade, 6’ Wicked bucket, SVL 65-2 w/4 in 1 bucket
Jan 17, 2022
446
819
Andover, KS
trial and error
Feb 16, 2023
394
386
NY
To the OP, if it makes you feel better I had a customer whose house we where framing several years ago when I worked for my brother lift me up on nothing more then a pallet with a peice of 3/"4 plywood on thetelehandler forks to do the house wrap. She was a fairly novice operator, I would put the machine in postion so she just had to lift me without moving the machine she would raise it up I would do as much as I could she would lower the boom I would maneuver over to the next section rinse and repeat. So... things are only as "dangerous" as you make them
GrizBota
Apr 26, 2023
1,147
733
Oregon
If your a little handy, think "C channel, inside of a C channel" and a series of holes to make it adjustable.
Damn it....I don't even need one of these things, and now I can't stop thinking about how to make one!!!!!!!
Funny. Same design the crossed my mind after seeing Mike’s cute sheet metal version.
FTG-05
Jul 21, 2013
346
190
TN
I started with a used $25 IBC container:
Add an ammo box for tools:
Changing a light over the garage. Not shown: The 10' ladder I use to climb into the platform, nor the doubled 2x4's I use as a safety catch in case of catastrophic hydraulic failure.
Adding a cell phone antenna to the side of the house.
Tree work. In this case, I put the basket/platform right up against the tree. This stabilizes the platform and prevents it from falling if the hydraulics fail.
My cousin and I installed this 2m ham radio antenna the last time he was here. We couldn't have done it without the tractor forks platform:
Thanks for looking!
MountainMeadows
Jun 6, 2022
220
291
Poconos, PA
Thanks for all the info and suggestions guys.
I think I'm going to get an IBC tote to modify. I can pick one up for less then half the cost of the platform I've shown.
I've also been considering IBC totes for firewood to lessen the handling time moving it from the woodshed to the house so this will be a good opportunity to give both a shot.
NorthwoodsLife
Oct 15, 2021
1,410
1,475
Wisconsin
One other thing...don't use this for your employees. When someone gets hurt YOU will be liable. Rent/buy a man-lift and keep it certified and inspected.
Yep. OSHA would have a field day on this one.
