Should I shim this Axle Slop
Benedict
B7100
Sep 15, 2023
17
Los Angeles
Hi as the title says, should I shim this Axle slop? I just bought this B7100 and this slop seems to much to me but I am not sure? Should the Axle be forward or backward?
SDT
multiple and various
Apr 15, 2018
3,323
1,103
SE, IN
Shiming worn axle hubs is at very best a temorary solution.
If the hub clamps cannot be properly tightened, the only proper solution is replacement hubs.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
Yes, shim it if you'll like. My B7100 had a little slop.
Shim it 50/50, front and back. Unless a mount is bent, or you can see excessive wear on the front or back... if so, shim it there.
Driveshaft length shouldn't be an issue, but check it if you think it is.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
It's the axle to frame pivot, not the hubs.🙂
Benedict
B7100
Sep 15, 2023
17
Los Angeles
Appreciate your reply, it’s a little hard to see, the play is in the main axle mount pivot.
9,430
Fixing that is incredibly easy.
No shims required.
Tighten the nut.
Takes the slop right out of it!
2,881
The hubs may be sloppy = but the pivot pin is worse!
SDT
Apr 15, 2018
3,323
1,103
SE, IN
Misunderstood.
Assumed you were speaking of rear axle hubs, which is a common problem on such tractors of similar age.
trial and error
Feb 16, 2023
394
386
NY
No shims required.
Tighten the nut.
Bingo. just make sure if you are using a gear wrench to tighten the nut and the closed end falls out of the wrench you don't spend hours looking for the part of the tractor that you just broke, when the crack you heard was the wrench end separating from the body of the wremch . Ask me how I know lol
That was a scary night and actually took me days before I discovered the wrench was missing a large round peice of metal. Imagine my relief when I found what actually broke wasn't a part of the tractor front end
