It ran fine, I parked it and the next day I had no lcd display & it wouldn't even try to start. The battery is good and reads 12.49v but just to try I hooked it up to cables getting 14v from another vehicle. The headlights, outside cab lights, low battery light and preheat all work. All the fuses between the feet in the fuse box look and test good as well. I have seen all the safety switch problems, so I checked their continuity. I think the 2013 only has 5, but I'm not 100% sure, and they all test good. Not only that, but I tracked the 12v to the opc it clicks when I turn the key to run. Is this normal or bad, and is there a way to test this controller/relay? The 12v does exit the relay when key is in start position. I absolutely hate electrical, and it's not my forte, but I am very mechanically inclined. I was born and raised on a farm, so I know a lot about a little and a little about a lot. A jack of all trades, master of none kind of guy. Any help would greatly be appreciated. Thanks in advance!!
