UnEasyRider
L3302 LA 526 loader, Box Scraper, Grappler, Forks, Rotary mower, Big Tool Rack.
Well, now that you asked, ANY grease is better than no grease!!!New to tractors and grease guns. What grease do ya'll recommend???
Moly doesn't necessarily make a grease EP, but K calls moly fortified grease out as a recommendation in their IOM. Hmm....Tractors aren’t exactly high-pressure, heavy equipment applications that require a high Molly grease.
Honestly, what you use isn’t nearly as important as how often you use it.
Any decent lithium based grease, used judiciously, is going to make your machine more than happy. Generic “red” grease will do just fine.
Almost all lithium-complex grease is fortified with “pressure additives”, which are along the lines of what moly brings to the table.Moly doesn't necessarily make a grease EP, but K calls moly fortified grease out as a recommendation in their IOM. Hmm....
Pretty much thisI use red-n-tacky in everything, but that question is like asking what oil is best. Lucas Red "N" Tacky Grease is a smooth, tacky, red lithium complex grease fortified with rust and oxidation inhibitors. It has good water resistance and washout properties. It has excellent mechanical stability and storage life. It is able to withstand heavy loads for extended periods of time. It can be used in many agricultural, automotive and industrial applications. Lucas Red "N" Tacky Grease is fortified with a high degree of extreme pressure additives that give it a TRUE Timken load much higher than other greases of this type. Its especially good for sliding surfaces and open gears.
As for grease guns I use a Milwaukee M18 grease gun with a lock-n-load coupler,
Yeah, but as I said- moly does not make the grease EP/ EP2. There are other additives that are used. A lithium complex EP grease can be 0%, 3% or even 6% moly.Almost all lithium-complex grease is fortified with “pressure additives”, which are along the lines of what moly brings to the table.
Sure, you could lube things twice as often with the wrong stuff and get away with it. I'm not arguing that, but you saidLike I said, the frequency of grease application is far more important than the type of grease used. Pick something cheap & readily available, use it often, and your machine will live a long & happy life.
That is not accurate at all. There are numerous lube points that are sliding metal/ metal. Exactly what 3-6% moly is used for, The IOM even calls for it specifically.Tractors aren’t exactly high-pressure, heavy equipment applications that require a high Molly grease
At the moment loader arms, grappler and rotary mower. Be nice if there was a general purpose one but it sounds like thats not gonna be the case.Well, now that you asked, ANY grease is better than no grease!!!
There are different types for different applications.
SO a better question might be - WHAT are you greasing?
Sounds like a really good grease...is it also high temp???I use red-n-tacky in everything, but that question is like asking what oil is best. Lucas Red "N" Tacky Grease is a smooth, tacky, red lithium complex grease fortified with rust and oxidation inhibitors. It has good water resistance and washout properties. It has excellent mechanical stability and storage life. It is able to withstand heavy loads for extended periods of time. It can be used in many agricultural, automotive and industrial applications. Lucas Red "N" Tacky Grease is fortified with a high degree of extreme pressure additives that give it a TRUE Timken load much higher than other greases of this type. Its especially good for sliding surfaces and open gears.
Thank you.Pretty much this![]()
I'm new to tractor'n too, however, I have been using Lucas Red N Tacky for many years on just about everything.
I have the Dewalt grease gun though.
FWIW, my local auto parts stores have it in stock - again. It was no where to be found for a while, but fortunately I still have extra tubes. I will be stopping by tomorrow at one of the local Advance Auto stores to buy a couple of extra tubes; they have 4 (confirmed by employee) in the rack.I've been using Lucas X-Tra Heavy Duty grease everywhere on my tractor and implements with excellent results. Unfortunately the X-Tra HD grease is n longer available for some reason and my 10-pack I nabbed in 2017 when I bought my tractor is almost gone, so probably going to get Lucas Red N Tacky when the time comes.
