Storage On A Tractor - Kolpin Gear Basket 53360
GrizBota
Apr 26, 2023
1,147
733
Oregon
In post 7 I mentioned I appreciate how the storage basket doesn’t obscure the tail lights. I realize the turn signals that are mounted on top of the rear fenders aren’t visible in the photo I included therein. It’s because the picture was taken too close up. Below is a photo that better demonstrates this point. I had the L out and about today for towing duties and since the FEL was mounted, I dinked around and found some FEL stuff to do.
GrizBota
Apr 26, 2023
1,147
733
Oregon
Well today the B2601 got a better pretend tool box bolted to it. I removed the dealer’s pencil box “tool box” and replaced it in the same location with a plastic 0.30 caliber ammo box, flavor orange of course. It is mounded in the stock location behind the seat on top of the thin gauge piece of sheet angle that goes from one fender to the other, in the same vertical plane as the ROPS.
At a minimum it will be good for temporary storage of beer cans and trash I pick up that the good folks in my area discard on the roadside that I find while mowing the R/W.
Here’s a four photos.
UnEasyRider
L3302 LA 526 loader, Box Scraper, Grappler, Forks, Rotary mower, Big Tool Rack.
Apr 14, 2023
136
68
Florida
Looks great! Now where can I get one???…lol
GrizBota
Apr 26, 2023
1,147
733
Oregon
Thanks. I think I got that one at Bi-Mart. Although I’d guess Amazon might have an orange ammo can.
GrizBota
Apr 26, 2023
1,147
733
Oregon
I got the chainsaw mounts dry fitted today. I cut the stock mounting hooks off the top and drilled and bolted them on to the Kolpin basket.
These are the “Bannon Chainsaw Holder” got them on Amazon for $60 each.
The thumb screws are on a bolt, the head of which is on the back of the rear plate, so it’s not flat. Those bolt head are about 5/16” proud of the back surface. They were about 3/32” proud when I got done, although I kept nearly all the weld, so I didn’t loose any strength. This allowed the chainsaw brackets to bolt flush to the basket top and bottom rails.
IMG_1864.jpeg I
I might start another tread in a few days with the details as to the modifications I made to mount the chainsaw brackets. Probably after I finish painting them to pretty up the cutting and grinding I did.
5,294
View attachment 111612 I
I love the concept; However speaking as a card carrying representative of the "vertically challenged", I think it might be slightly problematic.
GrizBota
Apr 26, 2023
1,147
733
Oregon
I hear that. I won’t be loading or unloading them from the downhill side.
After this is effort is complete, next up is some trickery to mount the pole saw on the right side of the open station. While permitting full function of the FEL.
Then the grapple, three saws and a wood spitter (or trailer ) will roam the woods making piles and firewood. Fewer trips back to the shop to get all the tools on site. Might put the wood splitter behind the ATV.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Strong enough to hold some pretty heavy items.
Threw my gas powered post hole digger/auger in the tote basket this afternoon.
Had a bunch of other stuff in the FEL bucket.
It's a fairly heavy item....but the basket held it fine. Just had one 6x6 post to set....so not going to fool with the 3 point auger for that.
trevoroni
B6000
May 24, 2023
205
254
This basket is on sale during Amazon Prime days in Canada at least.
It has been normally around $200 CAD now 30% off for $145 which is the lowest I've saw it.
Kolpin 53360
Yotekiller
Sep 29, 2023
459
579
Southern Indiana
Kolpin 53360
This basket looks IDENTICAL to the ATV basket I bought off of Amazon for $100 and bolted to the ROPS of my tractor.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
129
119
Lopez Island, WA
Well, I finally got around to adding a Kolpin basket to our B5100 with a sturdy (3" x 3/8") bracket fastened to the ROPS. As usual, I got to fix one of the brackets after tacking since I managed to make it mirror imaged.
The cross-bars supporting the basket are 3/4" water pipe; in order to get the half-holes cut in the brackets I tacked the two brackets together and drilled them that way:
