I’ve got a 72” rear blade for my B2650. It has a steel cutting edge. IF we get any snow I’ll be cleaning driveways and my church parking lot. Would the steel edge hurt the asphalt or should I look for a rubber edge ………. Thanks
I have used a steel blade on my asphalt for decades with no issues.I’ve got a 72” rear blade for my B2650. It has a steel cutting edge. IF we get any snow I’ll be cleaning driveways and my church parking lot. Would the steel edge hurt the asphalt or should I look for a rubber edge ………. Thanks
Successful "grading" with a rear blade requires much experience.Just to add to the conversation, I brought in class 2 for my dirt driveway. Tried using the back blade to smooth it out but it kept digging in. I spun the blade around. Worked fairly well smoothing it out.
Or for much cheaper, just unbolt the steel cutting edge and bolt a piece of plastic board like trex in its place.I would invest in a rubber or UHMW cutting edge. Asphalt is easily damaged. Check Good Works Tractors. They ship anywhere.
That’s the trick for smoothing with a blade, and it also works well for snow removal on a gravel road without disturbing the gravel.Just to add to the conversation, I brought in class 2 for my dirt driveway. Tried using the back blade to smooth it out but it kept digging in. I spun the blade around. Worked fairly well smoothing it out.
Have not tried it in the winter yet. Am hoping the snow pusher I bought works with out removing to much gravel in my driveway. Until it freezes hard, I suspect I’ll be taking some off the top. Was thinking of removing the blade and trim 1/4 inch off the snow pusher blade.That’s the trick for smoothing with a blade, and it also works well for snow removal on a gravel road without disturbing the gravel.
Just turn the blade around backwards and float it on the 3ph. It works great.Haven’t tried
