My question is, do I need to buy a subframe for my tractor to protect it, or is it a large enough tractor to be able to manage the attachment strains. Thanks.
Edit for photos.
It’s attached with the 3pt hitch only. I can get some pictures the next time I am at my parents to help out. Thank you.Do you have pictures of how that attaches? That will answer some questions.
You NEED to have a CUSTOM sub-frame fabricated.....ASAP!View attachment 110268 View attachment 110269 I am new to tractors and bought my first tractor with my dad, an L4200 with a front loader. It came with a backhoe 3pt hitch attachment which looks large for the tractor itself but works alright. It’s a low hour machine and seems very well kept, but the more I’ve been reading about backhoe attachments on tractors the more I begin to worry about damage I am putting it under. Videos and articles seem to say a subframe is the right solution. Unfortunately I don’t know what model the backhoe is as it’s older and rusted. I’m not sure where to even find this on the attachment. Hope these pictures help.
Subframes have to be specifically matched to the tractor model and the backhoe they connect to. The likelihood that one was made for your specific setup is very slim. As mentioned you will need to have one fabricated which will probably cost thousands of dollars. I would just use the backhoe very sparingly in loose material as needed and keep it off the machine when not in use. 3 PT backhoes are a huge compromise over a subframe mounted one, and can easily ruin your back end.It’s attached with the 3pt hitch only. I can get some pictures the next time I am at my parents to help out. Thank you.
So the casting reinforcement bracket is a must. Would it be fine to add that and not add a subframe?A reinforcing bracket like what others have shown is really essential for your L4200 if you expect to use that backhoe. There is a possble damage issue because if you catch the backhoe bucket on a root or a big rock, for instance, all the pulling the backhoe does goes right back into the rear differential through the toplink. The hoe probably has enough power to eventually break that casting wide open without the reinforcement.
But it's not just a tractor damage issue, there's also a possible safety concern since
a failure of the toplink or the rear end might cause the entire backhoe to suddenly lift and/or pivot on the lower 3pt linkage arms.
Kubota stopped offering the 3 point type backhoes several years ago.
Thanks for all your advice. I really appreciate the help. This is probably a dumb question, but how do I go about getting this part? Do I parts request Kubota or find someone who can make it for me?I'd think you'd be fine. The BH feet are in the ground, so the lower arms won't transmit much 'force' to the tractor ? The top link bracket on my D-14 is a wrap around style ,bolted to the read, top AND front of the rockshaft. If it ever breaks off, I've got a very,very serious problem. #7 post picture is similar to what I had made( clone of the 3 holer OEM bracket )
If you don't FORCE operations, as is, the BH will not do damage( tractor is fine now....) It's when you get AGGRESSIVE and/or do something STUPID, that 'stuff' breaks. As it sits, it'll dig miles of trenches in soil or sand, try to extracate a big boulder could cost you $$$$$$.
Mine was said to have been one of the last ones in stock, back in 2006 or so... Kubota stopped making them.....how do I go about getting this part? Do I parts request Kubota or find someone who can make it for me?
Suggest amend "great risk"..... to MAJOR RISK/LIKELIHOOD !The following illustration shows what the Kubota reinforced three point top link looks like (L4200 bottom right). There is great risk of pulling a piece out of the back off the transmission case if you don’t use one of these:
I think Great is larger in magnitude than major…Suggest amend "great risk"..... to MAJOR RISK/LIKELIHOOD !
After bracket is properly built/properly installed amend to .......some risk!
