Easier way of pulling down ROPS for storage
bbxlr8
Mar 29, 2021
442
305
Eastern PA
I used the cranks from an old set of pump jacks. Drilled a hole and connected with small screws, washers and nuts. Tethered to clip with crimped wires. turns of the crank gets it done.
I love the ingenuity and function but that would drive me crazy banging around with the way I use mine :p
5,185
Hey All,
I just got an L4701 and the ROPS are like 1 or 2 inches too tall to get the tractor in the barn. In any case, I went to take the pin and bolt out and it was a beast to get unscrewed and screwed back in... so much so that my tractor is currently parked outside because I really dont want to spend 20 mins getting the bolts on and off to store the tractor.
So, posting my first post here... becuase I'm 100% there is a trick to making that proccess easier. Do i need to grease that bolt, iuse a tool of some sorts, build a bigger barn? Whats a functional way to get that ROPS up and down but only take a few mins to remove/replace that bolt?
Thanks,
DC
Suggestion:
Build a bigger barn,....... and change the tractor model to an L47 TLB.
You got the "L47" correct, , .......but the 01 part is wrong. ;)
K7G
L2501HST, LA526 w/ L2248, BB1260, RCR1860, EA Disc Harrow
May 29, 2023
76
112
Aladamnbama
My shop’s double doors are too short for the ROPS so I’m always putting it up or down.
Since this is a pole/metal building, modifying the doors is an option. I thought about pulling out the doors and installing a roll-up door. I can pick one up at the factory which is about 80 miles away. That door is about $1300.
The other option is to add a horizontal door above the double door that I can raise and lower as I go in and out. It’s a simple matter of moving the 2x6 headers up about two feet. I’ve got some material that I can make a door out of and then, add a simple frame on the backside of the new horizontal door. That frame will act to catch the tops of the doors and I can add latches on each side along with weather stripping along all of the edges of an interior three sided frame. A rope, a pulley or two, a cleat and it’s good to go.
I also need to add louvers and an exhaust fan to help vent the building. These will be good fall projects…. and maybe a lean-to on the side too. Thank goodness I’m retired. Lol
RichOzz
L2501 HST w/LA525 66" bucket BH77 LA BB1260 RCR1260 EA 42" Pallet Forks
Aug 26, 2021
23
17
MA
On a few occasions the rubber cap on one the end at the folding ROPS has come dislodged, which binds things up & makes it very difficult to screw in the bolt. Otherwise, with a little grease once applied, the bolt may be turned in or out in 20 seconds.
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
Okay I have a different idea, low profile tractor tires. Got a Pasquali Tractor for my brother and all the rims were rust(calcium chloride) and tires dry rotted. Welded in some temporary patches, about one gallon of rtv(to make smoother, 4 tubes and some used tires(225/50R16) that were 3/32nds. Wish I had some pictures of it sitting, but here is a stock picture. Just imagine 1 inch tire height.
Trash Panda
L2501
Feb 18, 2022
92
71
Wyoming
Grind a slot in a cheap impact socket to fit the goofy bolt heads snugly, and burn em in & out with an impact. Costs about 3 bucks and some time with a grinding wheel.
The ugga-dugga gun takes no shit, and makes it a breeze.
ferguson
L3130
Jan 19, 2022
322
126
w.v.
Going with Run with Scissors Except REAM ( not drill ) HOLE & NUT to make fit as tight as possible / with a pin you are going to destroy the threads anyway.
TheMurf
BX1880.with loader and 48 inch deck. 1990 Gravel 12G Riding tractor.
Jun 25, 2022
160
72
Upstate New York
To solution the ease of raising and lowering the ROPS. I installed spinner knobs on the thru bolts. I no longer have to get a wrench and a ratchet to tighten or loosen the upper folding ROPS arm. The spinners stay nice and tight by hand,they are not going anywhere.. Easy fast and convenient. McMaster Carr has them..
4,415
5,185
Excellent solution!
Jasonized
L3902, LA526, box scraper, grapple, pallet forks, tree ripper, lane shark 3
May 16, 2023
156
41
California coast
I guess I’m lucky…. My “barn” doors are 14’ tall, so I don’t have a problem. Even my house, when I drove up to the garage, turns out the rops is about 2” less than my eves overhang, so as long as I didn’t have to go into the garage (can’t see a reason to), I don’t have to remove anything.
of course, I did find out I have to be a bit more careful when driving under trees that I always went under when mowing…. sigh. 🙄
