If you're on a rebuild, waiting for ordered parts the most time spent. Plan in advance but doing it shadetree you'll forget something. And with no supply in your 'parts dept' you'll be waiting for parts.
With your two engines to salvage into one, there are parts you should buy new anyway. Gaskets and the like, of course.
If you use the block from one, definitely use the same main bearing caps, the crank shaft and rods and pistons. Unless you're really skilled with a machine shop.
If you use the head from another, use the whole valve train.
Is it a pushrod engine or OHV.... Cam shaft, timing chain...
"You'll be waiting for parts"
Thats ok, it is the most economical way to repair engines
Otherwise, your ordering parts that you thought you would need
They can get pretty expensive, even small parts
"two engines into one, you need to order parts anyway"
Yes, I'll probably get genuine japanese gaskets from messick
"If you use the block from one, definitely use the same main bearing caps, the crank shaft and rods and pistons."
Yes, meaning:
Those parts were honed specifically for that block. If I order a new one, it might be a little off because they are fitted.
"If you use the head from another, use the whole valve train."
Is your statement saying: do not open the head and try to rebuild it, its too finicky and not worth the hassle. Get a whole head already put together by machine shop.
Ok yes, I did find genuine kubota rebuilt head
Shop our inventory of rebuilt Kubota D1301 Engine at unbeatable prices. Enjoy our hassle-free online checkout or call to speak to an expert.
www.vanderhaags.com
it says, rebuilt with the valves...$1600...
The chinese knock off: $400-500
"Is it a pushrod engine or OHV.... Cam shaft, timing chain..."
I think it is overhead valve, I'm pretty sure there is no timing chain, I think it is timing gears. I think it has a camshaft.
I'm not really good with the vocabulary, but I can fix stuff.
