Project #2 chute deflector mod
MNGB
B2601 & BX 2822A snowblower
Aug 3, 2023
26
29
WC Mn
The snowblower on the B2601 came with hydraulic lift and hydraulic chute rotation but has a manual deflector on the chute, in the past I have not changed the deflector all the much but the Agri-fabs on the Husqvarna had a cable lever assy that could be used from the tractor seat, so I decided to install an electric linear actuator to operate the deflector. So I ordered a actuator from EBay it came with 2 end clevis pins has a 4" range and its fairly slow which is ok for this use and the spec says it has lots of push/pull power, although not a real big deal in the use. Today I worked out how to mount the actuator to the chute and started on wiring the switch and the wire cable to go from the blower to in the tractor cab. Got a good start on it today
20230809_092045.jpg 20230809_092923.jpg 20230809_152616.jpg 20230809_152625.jpg 20230809_152639.jpg 20230809_152644.jpg 20230809_152654.jpg
MNGB
Aug 3, 2023
26
29
WC Mn
Worked on the switch wiring and a switch mount for the linear actuator plan to install the switch on the hydraulic control joystick
MNGB
Aug 3, 2023
26
29
WC Mn
Got the switch end wiring done and the switch mount done, so its to its to paint the switch mt and feed the wire from the cab to the front of the tractor and make the electrical connections and to finish up the linear actuator mounts
20230811_144317.jpg 20230811_144339.jpg 20230811_144356.jpg 20230811_152154.jpg
2,500
That will be a nice addition I bet.
So thats a momentary switch for "up and down" I am guessing?
MNGB
Aug 3, 2023
26
29
WC Mn
Got some work done on the wiring this AM got the ground in the cab connected and got split loom on the cable to protect it, installed a circuit breaker next to the battery for the power lead and got that installed did a quick connection using wire nits to see if it was functioning as it should and it is so far so good
20230814_093406.jpg 20230814_093412.jpg 20230814_093422.jpg 20230814_093502.jpg 20230814_093512.jpg
Hahnsolo
B2650 Tractor, B2782B Snow Blower
Mar 13, 2023
108
183
Rocky Mountains
Very cool. I had the dealer of my used B2650 put a linear actuator on the chute, just like you did, but the switching controls were kind of clunky. I found a replacement joystick handle on ebay and modified it to hold a two-way rocker switch on top for thumb operation. Sure makes a big difference when blowing snow.
Solo
MNGB
Aug 3, 2023
26
29
WC Mn
Finished up the wiring today except for installing zip ties on the power cable along the tractor frame, otherwise got the split loom installed and everything zip tied in place. Tested the movement of deflector and its good to go, tomorrow its to finish up the linear actuator mounts and then painting
20230815_150900.jpg 20230815_150914.jpg 20230815_150928.jpg 20230815_150945.jpg 20230815_150949.jpg 20230815_151007.jpg
2,500
Very nice work MNGB.
Do you have a cover for the back of that switch?
MNGB
Aug 3, 2023
26
29
WC Mn
Today while installing some foam pipe warp to the windshield braces an idea came to me for a cover on the back of the actuator switch, so I gave it a try I think it just may work
2,500
View attachment 109891 View attachment 109892
I was thinking of finding some sort of black plastic box to encase it.
At minimum, get all black zip ties, you don't want the neighbors talking behind your back...:)
