I am wondering if anyone out there has an electrical wiring diagram that matches my tractor--I purchased a work shop manual and the electrical is close to what I have but does not match for all items. I am trying to fix problems with start relay and stop solenoid not energizing when key is turned on and no voltage to start relay in start position. In the process of trouble shooting--i have found no 12volt power to the start relay or the stop solenoid---all the safety switches are closed to provide ground to both relay coils--Im missing the 12volts. According to the wiring diagram the power comes directly from the main start switch ---I have removed the wiring harness completely from rear of tractor and have found I have a white/black wire that is powered up in start position and should go to my relays---it goes to a black box located on top of transmission{below seat} that has 10 wires going to box. The box has numbers k3511 55222 and Taiko 0522--any body help me as to what this box does and why is not on wiring diagram?? I checked my parts manual also and could not locate this device--apppears to be a solid state relay.
