Ok this has been a nightmare. My tractor was leaking fluid from around the drive shaft. I took it to a repair shop to be broken in half and a seal replaced as all the research I did said that was what needed to be done and the mechanic said the same thing. He had it for 10 months and I finally said I'm coming get it fixed or not. I got there and it was still broke in half and he was working on it. He got it back together a couple of days later and I went and got it. Now the 3 point hitch system doesn't work right, the transmission isn't working right either. When you put it in gear there is a lag before it moves or it won't move until you put it in or out of gear a couple of times. Also it moves at the same speed in all gears pretty much. The steering is working fine and I put the front loader on it and it works just fine and now I can raise the 3 point hitch while I'm tilting the bucket but it will only work while I'm tilting the bucket. Nothing if the bucket isn't being tilted at the same time. Everything I have read says it doesn't need to be bled so if there isn't air in it anyone have any experience with something like this? Thanks
