Removing top material from driveway…
Jasonized
L3902, LA526, box scraper, grapple, pallet forks, tree ripper, lane shark 3
May 16, 2023
153
41
California coast
Hey folks,
I’ve decided I’ve had enough of dust from my dirt driveway, and have decided to try putting down NDS tufftrack pavers…. Basically, 1.5” deep, 2”hollow hexagons, and filled with pea gravel. So I need to scrape off about 1.5” off the driveway.
What’s the easiest way to get a mostly flat surface? It’s composed of standard road base, so has a bunch of small stones, of course.
Ive tried scraping it off with my boxblade to break it up, then back dragging to get it somewhat flat. Then hand shovel/rake to smooth it.
Thinking of spreading a thin layer of sand to smooth it better…
Any better ways? All hints, constructive tips are welcome!
Thanks!
3,107
Land Plane.
It doesn’t actually remove product…but it makes it smooth and level.
4,169
if your box blade has scarifiers, put them down 2" and pull. THEY break up the material. Then raise them up, pull BB again to remove the material.
Jasonized
May 16, 2023
153
41
California coast
Land Plane.
Well, yes, and no... Smooth is relative! I do have a small (towed behind my garden tractor) land plane.. It levels stuff out, sorta. But the rocks involved don't help much... :} And they are poking up, and lift the tufftrack off the ground.
But yes, I'd forgotten I had one of those. And it will hook onto the back of my tractor....
Probably have to add lines to the 3point, so I can lift it up when backing up.. <smile>
Jasonized
May 16, 2023
153
41
California coast
It does, and that's basically what I have done so far. Then went back (since it wasn't *that* flat), and did some hand flattening. And smoothing with a (hand) rake.
If that's the best I can do, well, there ya go. I was hoping for something that would work a bit better, but as it is, I think the rocks are defeating me. Guess dusting with sand afterwords (to fill in around the rocks) is probably the best I can do right now.
Thanks!
Jason
nbryan
Jan 3, 2019
1,170
712
Hadashville, Manitoba, Canada
Box scraper is the tool, IMO.
And putting some finer surfacing gravel over that stoney pit run fill will indeed produce a nice smooth and flat finish, it's just a matter of careful and patient adjustment and operation of the boxblade.
For the last passes I've adjusted my BB with a heavy top link tilt to the back so to smooth with the rear scraper and not pick up fresh material. Can play marbles on that sand surface after that.
Jasonized
May 16, 2023
153
41
California coast
that’s what I was trying to do! Okay, don’t have hydraulic tilt on my tractor yet, so it’s slow going. I was just wondering if there was a better approach or not.
I did use the scarifiers to break up the top most layer, then pulled material out, then ran back over it with the rear blade to ”smooth” it. I don’t have much sand yet, but wasn’t sure if that was the best way to go.
Thanks all, I’ll keep going and see how it goes. Just have a smallish section under test, to work things out before I buy lots more of the tufftrack.
Cheers!
4,161
Box blade 100% in my book. YMMV
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,421
2,340
You say "base" and not sub-base. So i assume this is like 57's. Not larger #2s whickmh are fist size. There is another thread around here where an orange addict did just this task with a BB.
Jasonized
May 16, 2023
153
41
California coast
yeah, 3/4- road base, pretty standard around here…. Still, especially up near the house, I get larger rocks. So, probably thinner there than father down the road.
Thanks! At least I’ll get lots of practice!
G.rid
L48 tlb, ssqa forks, manual thumb for hoe
Aug 19, 2016
207
17
Oxford, NS, Canada
What about renting a plate compactor to get the final smoothness that you're looking for. It should either break up or drive down the odd high stone that's giving you grief.
I'm not familiar with the product you're using, it may need packing also.
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
Or a vibratory roller. Or back in the old days my grandpa used to spray used motor oil on the gravel to keep the dust down. I don't think the EPA would approve of this nowadays, but, it did work and did not track too bad. I think the OP is talking about geotiles or something similar. Does the OP get snow as I would worry about plowing.
Jasonized
May 16, 2023
153
41
California coast
Yep! That‘s the unit!
Hmmm… plate compactor…. That’s possible, if I can find one locally. The base itself is really packed hard, as it‘s over 25 years old, especially up at the house.
Nope, no snow! CA west coast…. rain in the winter.
I think a flat plate might work…. But I was thinking on what I have, since I’ll be doing this in stages, as I get the cash for materials. Renting would quickly mount up.
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
I have found a few plate compactors on FB for around the 600 dollar range. I would buy a less abused one and then sell it after the project was over(okay I don't sell tools/toys).
Jasonized
May 16, 2023
153
41
California coast
Hahaha… yeah, I don‘t sell tools either…
okay, found one for 500 or so, and free shipping. Not the best, not the worst.
reviews were okay for it.
Something else I can now learn to use!
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,421
2,340
Here is the thread I was thinking of. Not the same project though. However, he did scrape and level with the BB
FWIW, pea gravel will not compact. It will always be loose. Keep that in mind.
Jasonized
May 16, 2023
153
41
California coast
Thanks, read the posts. Not quite the same, but some good info.
Pea gravel goes in the hexagons, not under. No packing involved!
Cheers!
2,260
I used my front plow blade:
4,335
Is what you are describing as "3/4" road base, plain 3/4" washed stone. or is it "3/4" minus", which is everything that will pass a "3/4" screen ( and compacts like concrete)?
Jasonized
May 16, 2023
153
41
California coast
Sorry, should have written out “3/4 minus”. Yep, everything that’s left after larger screens are done. Packs a lot like concrete, hence the need to break up the top layer before leveling. Dusty, though.
But even so, I still have enough rocks in it to make leveling difficult.
Hopefully the compactor will fix what I miss, or at least flatten it if I put a little sand on top as well.
Holding off on the sand until I try the compactor first…
Also, time to finish mounts for my tilt/twist valves for my BB! Now that I have a real reason instead of just convenience.
